Car won't turn over
I've tried turning the car over twice already.
If I don't have all the sensors connected, could that be my problem? I have all the grounds throughout the car, the starter connected, and the 'important' plugs in. I'm going to plug them all in but if I run into this problem again, I'm stuck.
Also, the harness I'm using which is the correct one for my b18a1 swap, doesn't appear to have the plug for the clutch pedal position switch (cpps)
I'm 100% sure that this probably my reason why I get no reaction from the engine at all
The only weird thing is, that I have extra harness' laying around (exact same one) and they don't seem to have the connection either.
Can anyone tell me where there's is locate on their harness?
Also that switch is located right above the clutch pedal. Close to the firewall. Way behind the dash.
owneyboy
Oct 13, 2012 05:59 PM
rmnS2K
Mar 5, 2006 03:13 PM
