Radiator Fan Won't Come On At Low Speed/Idle
Old Aug 26, 2013 | 10:48 AM
Bleakened's Avatar
Default Radiator Fan Won't Come On At Low Speed/Idle
The title says it all.
I have a 98 DX Hatch and at speeds anywhere from stopped while idling to about 20 mph, the radiator fan won't come on. It will let itself overheat until I speed up to 20+ mph. Sometimes will really act up and not come on until I hit 45+ mph.
I have replaced the:
-Fan Relay
-Fan Switch
-Thermostat
-Engine coolant temperature sensor
And nothing helped.
One thing I notice sometimes is that the car will vibrate for about 1-2 seconds (as if the fan came on) and then I can actually watch the temperature gauge go up semi-quickly.
Anybody know what's up?
Old Aug 26, 2013 | 11:54 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: Radiator Fan Won't Come On At Low Speed/Idle
Have you tried running power directly to the fan to see if it works?
Have you tried jumping the fan switch to see if it works?
Old Aug 26, 2013 | 12:00 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
Bleed the air out of the system
Ensure thermostat is operating correctly and nit on backwards.
Bleakened's Avatar
I have, yes. It works fine that way. Also note that I replaced the radiator and flushed the system and re-filled it as well. (for other reasons)
Old Aug 26, 2013 | 12:02 PM
Bleakened's Avatar
How do I bleed it properly? I flushed it, refilled it, ran it hot, let it cycle then filled up it the rest of the way the next time it was cold.
Thermostat only goes in one way and the built-on seal has 2 notches that line up with the housing to ensure it only goes in the right way. It is also only a few months old.
Old Aug 26, 2013 | 12:06 PM
24TEN's Avatar
PHANTOM MENACE
Works which way? Those are two different tests.
Old Aug 26, 2013 | 12:08 PM
Bleakened's Avatar
Oh umm, it worked when jumped. Never ran power directly to it.
Forgot to mention in original post: fan switch is new too.
Old Aug 26, 2013 | 12:13 PM
24TEN's Avatar
PHANTOM MENACE
If it works when jumped at the switch, either the switch failed or you have a break in continuity between the fan and the switch. Given that it sent power if you bypassed the switch altogether (jumping the switch) you should be able to assume the wiring is fine and that the problem is the switch. The circuit is simply an on/off switch. Either it sends power or doesn't. If you want to verify you should pull the switch and see if there's any resistance when its probe is at operational temperature (simulate by placing it in boiling water like you would when testing a thermostat).
EDIT: Grammatical
Old Aug 26, 2013 | 12:22 PM
Bleakened's Avatar
If it works when jumped at the switch, either the switch failed or you have a break in continuity between the fan and the switch. Given that it sent power if you bypassed the switch altogether (jumping the switch) you should be able to assume the wiring is fine and that the problem is the switch. The circuit is simply an on/off switch. Either it sends power or doesn't. If you want to verify you should pull the switch and see if there's any resistance when it's probe is at operational temperature (simulate by placing it in boiling water like you when testing a thermostat).
I'll have to do some testing on the switch then. I'll look into it.
Also, I added a small detail into my original post if it makes a difference.
Old Aug 26, 2013 | 01:00 PM
dueyx99's Avatar
you said the fan is coming on at 45mph ?? the fan is useless at those speeds, i believe the cooling your seeing is the actual airflow through the rad, only way to test the fan operation is to let the vehicle sit and wait for the engine to get hot enough to trigger the fan, if the fan does not come on, yet you can trigger it by manually jumping the connector, i would suggest trying NEW parts, not new-to-the-car junkyard parts
Old Aug 26, 2013 | 04:59 PM
tony_2018's Avatar
Fish Twig
You don't jump the switch, you jump the plug that goes to the switch. Are these oem parts you replaced them with or parts from a pepboys/autozone/advance auto/napa?
Old Aug 26, 2013 | 05:28 PM
Bleakened's Avatar
They are new. Never been used.
They are aftermarket brands but yes, from Autozone.
gitarman2
May 26, 2013 03:58 PM
jodyboy
12
Aug 15, 2012 09:39 PM
chrisalvar
Jan 29, 2012 05:15 PM
JDM_SiN_CiViC
May 8, 2003 10:46 PM
Mikey3000
Jul 12, 2002 09:03 AM
