Honda CR-V & Element 2WD & 4WD Element & CR-V
1998 CRV obd code P0108
Old Aug 25, 2013 | 10:28 AM
rfm98crv's Avatar
Default 1998 CRV obd code P0108
I have been getting this code for the map sensor high output voltage. Tried a new MAP sensor, cleaning throttle body and checking for vacuum leaks, all to no avail. Can drive at low speeds without throwing code, but under load (up a hill) at 45 mph or better the CEL shows up and the P0108 code is read. Anyone have any suggestions I might try? Thanks for much for any assistance.
Old Aug 25, 2013 | 08:26 PM
Sticker Bomb's Avatar
Default Re: 1998 CRV obd code P0108
Damn the pictures changed.
Old Aug 26, 2013 | 03:21 AM
jmarshall098's Avatar
The cause and remedy of error code p0108 can be found in the hyperlink http://www.obd-codes.com/p0108
Old Sep 2, 2013 | 05:08 AM
rfm98crv's Avatar
thank you very much for the link. I was able to diagnose and determine that the "new" MAP sensor was faulty and traded it for another. Car is back to normal now.
aptyk88
Oct 15, 2008 12:49 PM
93sidelsolvtec
Jan 28, 2007 11:58 AM
Nextelbuddy
10
Jun 19, 2005 07:24 AM
ILLICON3000
Aug 4, 2004 03:25 PM
kaj
Sep 27, 2003 09:36 AM
