Is a P28 ECU okay?
Old Aug 25, 2013 | 10:25 AM
ThumperDumper's Avatar
Default Is a P28 ECU okay?
Im going to try a P28 ECU on my H22 to see if it will finally run, Should I use this one or try to find the 72?
Old Aug 25, 2013 | 11:06 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Is a P28 ECU okay?
It should absolutely run like ****.
Old Aug 25, 2013 | 11:20 AM
slowDB7's Avatar
You could chip the p28 and run the h22 map on it
Old Aug 25, 2013 | 12:34 PM
currently it has a p06, But i think the ecu is all messed so which should i put in?
Old Aug 25, 2013 | 01:49 PM
slowDB7's Avatar
If its a stock h22 is say get the ecu its supposed to have
But the choice is up to you and it will never run with that p06 you already have
Old Aug 25, 2013 | 05:15 PM
The Grumpiest
Is the P06 chipped or something? ECUs for H22s rare or something?
Old Aug 26, 2013 | 06:56 AM
Bought the car with it? It was dyno'd SO my guess it was chipped as there is already a rev limiter in the car( Guessing its in the ECU). Should I go to a P13 or not? This was running fine for 6 months then shut off on me.
Old Aug 26, 2013 | 09:47 PM
jlamp's Avatar
mine ran when I tried the same thing but it didn't run like it was supposed to highly recommend you get the 72
Old Aug 27, 2013 | 06:44 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Awesome advice recommending a gsr ecu!!! If you dont know, you should keep your mouth shut!!! A fool opens his mouth showing the world he is a fool, while the wise man keeps quite and listens!!!
Old Aug 27, 2013 | 08:44 AM
The Grumpiest
It was dyno'd? On what EMS? Or is it only chipped?
Old Aug 27, 2013 | 10:55 AM
Said it was programed on neptune
Old Aug 27, 2013 | 06:40 PM
The Grumpiest
Said? You don't know? So that means you don't know it was ever put on a dyno either. And how do you know the P06 is "all messed up"? Are you also guessing about this too?
WTF are we even changing the ECU out for? You never mentioned any of that. Probably why this thread has gotten absolutely nowhere.
Old Aug 27, 2013 | 08:38 PM
Dont want to mention it because as far as i know NO ONE know ive posted many on this forum with no response, 3 months ago, it started to pop a check engine light whenever i shut the car off for 5-10 min and couldnt turn the car on. Then 2 months ago it started while i was driving switching gears usually around 3000 rpm(I have a rev limiter at 3000, potentialy the problem?) And it happened to where it turns on maybe every other day but shuts off fast. This is what the problem is
And just to make you happy
Old Aug 27, 2013 | 08:41 PM
And ive had it at 2 different mechanics, who rewired everything and they say the problem is the ecu isent telling the injectors to keep a spark or something...
Old Aug 27, 2013 | 09:36 PM
holmesnmanny's Avatar
injectors don't spark
Old Aug 28, 2013 | 03:26 AM
The Grumpiest
Sparking injectors? How about take it back to the shop to was "tuned" at? What codes did it throw? Without knowing that you're just guessing just like you're doing now. This is what you get when you buy someone else's POS project and not familiar with what went into it.
This is why you don't start umpteen threads on the same issue. Now no one knows what been suggested nor what you've done, which seems to be nothing. First it was the battery that you didn't even want to get checked because it cost you $350. So what? Now you've decided it';s the ECU. Tell you what, get any ECU you want and see what happens since you like taking stabs in the dark rather than doing real troubleshooting.
Old Aug 28, 2013 | 06:35 AM
first off the computer doesent want to give any codes, 2nd I brought the car to 2 different mechanics and spent over 800$(total about 10-12 hours) so they can "find the problem/Diagnose" and that is all they give me... Thats all the words they tell me they said they get the car started but dies minutes later As that same thing happened to me but I could have drived maybe 50km before it would happen 2 months ago... And as I stated in my threads its most likely not the battery that was my first guess as people told me to check it and i did.
Something to do with the injectors not doing what its suppose to do and they keep telling me its the ecu or security system.
Appearently you can only read between the lines? As I answered most of your questions in my threads your just stating them in here where i didnt. And you just took your time to read them....
Old Aug 28, 2013 | 09:14 PM
Well took it to a better mechanic, needed a main relay, wireing to the distributor, re programmed ecu, and spark plugs
Old Aug 29, 2013 | 02:14 AM
The Grumpiest
But it was the ECU!!! The ECU was the problem! You said so! Because you took the proper steps to diagnose the issue! And your "mechanic" reprogrammed the ECU? Sounds like bullshit. If, and I mean if, a Neptune unit is in that ECU no off the street car tech has the skills to reprogram it.
Old Aug 29, 2013 | 08:33 AM
Yup i know thats what this store told me since I found out the previous owner built the car here... But he said he was either reprograming it or putting a new one in.
RACEPAK
Jul 25, 2009 11:45 PM
jays01
Engine Management and Tuning
Feb 6, 2009 07:35 AM
birwin12
Aug 3, 2007 10:21 PM
evolvedAP1
Jun 30, 2006 04:13 PM
