Oil on Spark plug??
My 90 CRX DX has a new (200 mi) engine D15B2. I pulled the spark plugs today and one of them had a little bit of wet oil on the threads, not the tip. The tips of all the plugs were a whitish grey dry coating. Look to be running a bit lean. I did a compression check and all cylinders were good. Cleaned and reinstalled plugs. Also advanced timing a bit since it seemed a little retarded. Any idea where this oil could be coming from? Valve cover seal or...? Thanks.
