No output to axles in s4c
I have a 95 hatch, just got done swapping my b series in and the transmission doesn't do anything in gear. The biotch pin was stuck in the shiftlinkage and it took some heavy hammering to get it out, so it may be the cause. Symptoms are when engine is off I can shift through the gears and everything seems to be clicking fine into gear. But I can put it in any gear, even reverse and roll the car like it's neutral. If I start the engine and put in gear same thing but my speedo works a little. If I rev the engine the speedo moves with the tach. So if I put it in first and rev to 6000 it shows me doing 50 or w.e. Which is impossible. Brand new (and correct) clutch, axles, and half shaft.
What can it be? The LSD burned out?
Pull it, split the case and find out. Sounds like the diff has lost its teeth to the axles somehow; the speedo is driven by the diff so it must be getting spun in order to see speed, but either the axles aren't in the diff right or the diff has no splines (I'd expect it to be still make noise if that were the case though). Easiest to just take a look IMO.
Thank you. I am certain the axles are in correct. If I open it up what would be a good rebuild? I'm thinking carbon synchros, and maybe a longer 5th gear. It is a DD and weekend warrior. No drag intended.
Jonknee
Jul 21, 2025 08:51 AM
94_DC
14
Nov 10, 2008 05:58 PM
ID_ten_T
Jan 12, 2004 07:08 PM
vtec69
14
Mar 29, 2003 12:20 AM
vrrodri
Sep 1, 2002 06:22 AM
