B20b vtec head gasket leaking
I have a HMO B20b and I put a type R head on I got the golden eagle ket with OEM gasket bored to 84mm brand new ARP head studs tq to 80 p
It leaking coolant from the front middle between runners 2&3 and running bown and pooling at the oil dip stick
I do see any smoke at all out of the exhaust and no coolant in the oil
Can any one help
Can any one help
Head studs were properly torqued? Who built the motor? Was the block decked or head resurfaced? how many miles were put on it until it started leaking?
the head studs are brand new never retort and the b20 was never split before now untilin i put the head on
and the head was surfaced and the same people surfaced other head and sealed fine
dont you have to remove the 2 brass rings on the exhaust side that hold the layers of the gasket together?
i think those golden eagle kits use vtec headgaskets, and ive know a few people who have externally leaked fluids using vtec gaskets in an ls or b20 vtec setup. ive always used the nonvtec gasket and never had externally leaking issues
I have the golden eagle head gasket so its a VTEC gasket so you don't have to remove those rings that's only if you the LS head gasket
Ok so I retort the head studs and cleaned everything up and started it up again and it's actually leaking from one of the studs that holds the header to the head so I unbolted the header and took the stud out and it was full of coolanthas anyone ever had this problem before
and just as a reminder it doesn't leak smoke or burn any coolant other than that
Looks like ur screwed,it appears that some one drilled out a broken stud and went too far in hitting the water passage,had to replace a cylinder head on a 1g talon for a customer after he attempted to drill out a broken exhaust stud,this is exactly where it leaked too.I ,might not be the case with yours but just something to look into.
good to hear, sometimes you dont need a fancy fix. now you just gotta remember that when you take the header off next and i pisses coolant out of the bolt hole lol.
