wiring up switches(hondata s300)
Old Aug 22, 2013 | 01:28 PM
hardcore97's Avatar
Default wiring up switches(hondata s300)
having some problems wiring up switches to use for high/low boost, one for launch control, and one for datalogging. i got on ffsquad and found the wire locations i wanted to use(A/C signal, P/S signal, and Brake switch) since my car is obd2a those locations should be C5, C16, and D5. i cut the wires and ran from the ECU to the switch, and then the other location on the switch to a ground. I went to check it today to verify it was working and when datalogging it shows all 3 of them on all the time, no matter which way the switch is flipped. am i doing something wrong here? the only other thing i can think of is my s300 is one with the obd2a adapter on it from hondata, but that shouldnt make any difference as i would still need to use the obd2a pinouts since thats what my chassis. any insight is appreciated! i am also searching right now to hopefully figure out my mistake(s). thanks
Old Aug 22, 2013 | 01:49 PM
xenocron's Avatar
Default Re: wiring up switches(hondata s300)
Do you have them all grounded at the same point?
Disconnect the ground, and see if they are all still on...
Old Aug 22, 2013 | 02:08 PM
hardcore97's Avatar
no they are not all grounded at the same point. disconnected the grounds and it was still showing up as on.
Old Aug 22, 2013 | 02:34 PM
Gunmetal_B20_Hatch's Avatar
are you pinning in on the harness side of your jumper harness or on the ECU side? I'd do it directly at the ECU if you can.
Old Aug 22, 2013 | 02:48 PM
hardcore97's Avatar
its not a jumper harness, its built on by hondata. got two working thats good enough for now. need to get it tuned and i will figure out the switch i wanted to use for datalogging later
Old Aug 23, 2013 | 01:43 AM
7rrivera7's Avatar
Would only be fair to share what you did to get 2 switches working...
TopEndTuner
Apr 28, 2009 01:18 PM
BB6-213
Dec 27, 2005 12:47 PM
DC4_MADMAN
Jul 16, 2005 02:36 PM
