Front brake upgrade
Ive installed the rear disc brakes on my 92 eg hatch but isnt there a bigger brake upgrade i can do to the front ? Like the rear disc brakes i think came off a integra so would the front brakes work from a integra ? If so what do i need to get and would i still be able to use the same drive shafts on my d15b if i had to change whole spindle and everything ?
Yes you can! I think integra GSR front brakes are bigger. The rotors and calipers I mean. Its a common upgrade. Try searching in the search bar. Good luck.
*you may have to upgrade the brake booster to accommodate the bigger brakes.
You'll need any integra front spindle assembly. Ls and gsr are the exact same. 10.4" rotors. Also ex or si civic again 10.4" rotors. Don't forget the prop valve 40/40 and a bigger master cylinder
'94 - '01 Integra front brakes. Civic EX also works, but the caliper piston is smaller. Use the matching master cylinder, brake booster and proportioning valve from a '94 - '97 Integra RS non-ABS.
streethondar
Jan 13, 2011 05:49 AM
