Transmission & Drivetrain Gearboxes, Differentials, Clutches
95 ls 5speed problems? ???
Old Aug 21, 2013 | 06:03 AM
mugen4door's Avatar
Default 95 ls 5speed problems? ???
OK i have a 95 integra ls i have several problems with the trans need a bit of help it's. a 5speed when i start it up and let it sit in neural it makes a slight grinding noise very faint when my foot is off the clutch and when i drive it when the car has sat overnight it shifts threw all the gears fine but when it gets warm it likes tho grind in 3ed if i don't slam it in also my shifter has a lot of play in it i did the rubber bushings but that did not help is it a shifter bearing.
also i would like to know if i get it rebuilt can i put a LSD in it and gsr sync rows in it seeing as there stronger
Old Oct 1, 2013 | 06:44 PM
mugen4door's Avatar
bump
Old Oct 2, 2013 | 02:32 AM
94acuralsv's Avatar
Default Re: 95 ls 5speed problems? ???
With the shifter play, do you know if your "b!tch" pin is in the shift lever that connects to the back side of the tranny or just a nut/bolt? Without that pin you could get a loose feeling shifter.
Old Oct 2, 2013 | 02:36 AM
Fliptard's Avatar
yes, the bitch pin that holds the shifter to the trans needs to be TIGHT, if you use a bolt it will have a lot more play in it. And I do not believe you can use GSR synchros in an LS trans.
Contact Synchrotech for a rebuild kit. If your going as far as adding an LSD into the trans, you might as well Spend around $800 for a FULL rebuild kit from these guys
Old Oct 2, 2013 | 04:03 AM
mugen4door's Avatar
pin is tight so tight i can't get it out and is the bottom of the shifter need a bushing
Old Oct 2, 2013 | 04:54 AM
Fliptard's Avatar
I have found that if you use a bolt that hold the AC pump on, its a long bolt, and hold it with a pair of vice grips is an easy way to knock the pin up and out. it fits perfectly up thro the hole and is long enough to give u room to hold it.
albanzek3
Jun 17, 2010 04:49 PM
BSERIEuS
Aug 25, 2005 09:07 AM
jweezy225
Jul 28, 2004 10:17 PM
mz3bo
Aug 30, 2003 11:25 AM
