trans and shifter ?
Old Jun 17, 2010 | 09:17 AM
albanzek3's Avatar
Default trans and shifter ?
have a four door gsr with ls motor and trans that i picked up today, noticed that it still has the gsr shifter and when in gear it moves side to side do you think its that damn pin and i also noticed that the shifts are short aand kinda click into gear could that all be related to that shifter or pin any ideas
Old Jun 17, 2010 | 09:58 AM
TheAsian's Avatar
Default Re: trans and shifter ?
The side to side play is due to the bushings on the shift stabelizer bar, and the rear shifter bushings.
Can you describe the the sound any better. Are you sure it is a oe shifter.
Old Jun 17, 2010 | 10:28 AM
albanzek3's Avatar
its not really a noise but a ruff click not as smooth as it should be and yes im sure its stock i thoughtsince it came from the stock gsr that was in it that i should get a stock one from an ls now the ls motor is in it
Old Jun 17, 2010 | 10:40 AM
TheAsian's Avatar
Ok. I would jack up the car and have a friend shift it from gear to gear. Check for the linkage binding. It is possible it may be become bent. You should be able to pin point the problem fairly quickley this way I would start with the linkage though.
As to the shift as far as I know all the oe shifters are the same
Old Jun 17, 2010 | 04:49 PM
NACvicSi's Avatar
My short shifter "clicks" into gear. If you have an OEM shifter maybe the bearing is going bad or it has been over tightened?
Vender-
Transmission & Drivetrain
Jan 26, 2013 06:21 PM
88EFhatch
14
Jun 8, 2005 06:11 PM
slipperyduck
20
Oct 26, 2004 08:14 AM
sloweh3
May 7, 2004 04:34 AM
dose
16
Oct 5, 2002 07:40 AM
