need advice on how to get my b20b to work in my eg
Old Aug 20, 2013 | 06:56 PM
JTRO15's Avatar
Default need advice on how to get my b20b to work in my eg
i recently bought a b20b longblock from hmotors and the distributor is my only issue and was wondering whats my vest solution whether i buy a certain jumpe harness for the distributor or can i use an ls one and also would i need to fab up a diff bracket to run power steering since the b20 one is way too big. ive searched for stuff havent exactly gotten the answer i needed i just want someones help to point me in the right direction much thanks for anyones help
Old Aug 20, 2013 | 07:04 PM
EsotericImage's Avatar
Retired Moderator
Default Re: need advice on how to get my b20b to work in my eg
Use everything from an Integra ls and it will bolt right up.
Use a OBD1 to OBD2 harness and use a P75 ECU. Have the ECU socketed and chipped for a B20.
Xenocron.com has verything you need.
Old Aug 20, 2013 | 07:37 PM
JTRO15's Avatar
thank you i just wanted to make sure i was on the right track of things. i got an ls computer that i was going to use and i was looking at rywires jumper harness. so the bracket from an integra will work to use power steering i have a pump from a gsr and the bracket isnt even close to working for it
blackhatch1215
Jan 28, 2012 07:57 PM
1point7db2
Jun 4, 2009 02:56 PM
Bizarre
Aug 10, 2007 11:25 AM
klownd
May 18, 2006 08:32 AM
GSRontheBottle
Oct 16, 2004 07:06 PM
