Terrible gas mileage
Old Aug 20, 2013 | 09:34 AM
gnxpro24's Avatar
Default Terrible gas mileage
I have an 89 Civic wagon pristine condition, just broke 80k. D15b2 getting 20mpg city. Both ef sedans Ive had with the same engine and auto transmission got 26-28 city even when one had 225k on it. Cant figure out why the mileage is so terrible on this engine. Ive replaced....
Water pump
Timing belt
Plugs
Wires
Rotor
Cap
Throttle body assembly
Fuel filter
Last thing I can try that I can think of is injectors. Any thoughts?
Old Aug 20, 2013 | 09:40 AM
sh1ntaox's Avatar
10 Year Member
Default Re: Terrible gas mileage
bad oxygen sensor possibly. old ignitor/coil maybe.
Old Aug 20, 2013 | 09:45 AM
4drEF's Avatar
Keyboard Humorist
Is your check engine light on?
Does the engine run awkward at any time?
Does the exhaust smoke?
Perform a compression check and lets see what your numbers are.
The O2 sensor could be on it's way out and is 'lazy'.
Injector cleaner can help clean up your injectors. I would start with that followed by a new fuel filter (after the tank of gas with the injector clean has finished) before throwing new ones in.
Old Aug 21, 2013 | 07:47 AM
gnxpro24's Avatar
Tried an o2 sensor. At very rare occasions it shudders or hesitates at idle. Timing is perfect. Also its been throwing a vss code 17 for the past several months at least. If theres a wire broken at the gauges for the vss signal would that throw off the computer resulting in terrible gas mileage?
Old Aug 21, 2013 | 09:46 AM
4drEF's Avatar
Keyboard Humorist
Does your speedometer work?
The stock speed pulser is mounted on the back of the speedometer.
If the cable drive from the transmission is disconnected or broken, then the speedometer doesn't work and same with the speed pulser.
Very unlikely that your wire from the pulser to the ECU is damaged unless you have been doing some wire cutting in your dash.
Old Aug 21, 2013 | 10:32 AM
gnxpro24's Avatar
Yep, speedometer works fine.
Old Aug 21, 2013 | 10:40 AM
4drEF's Avatar
Keyboard Humorist
You get to pull your cluster out and check the wire from the pulser to ECU.
If it checks out to be fine, then replacing the pulser (or simply replace the entire cluster).
Old Aug 22, 2013 | 06:14 AM
gnxpro24's Avatar
That's what I had planned. No one ever answered whether this explains the gas mileage or not.
Old Aug 22, 2013 | 09:30 AM
4drEF's Avatar
Keyboard Humorist
It can definitely effect your gas mileage.
coco718
13
Oct 5, 2011 02:27 PM
f22 lx
Apr 30, 2006 07:38 AM
jdadams12
Dec 27, 2005 10:53 PM
silentblackhat
15
Mar 31, 2005 09:04 PM
BDTURBO
Feb 25, 2003 04:36 PM
