Speedo doesnt work, help!
Old Aug 17, 2013 | 07:58 AM
bcintron95's Avatar
Default Speedo doesnt work, help!
Alright so last night my d4, engine, and speedo stopped working. ablock away from my house my speedo started going wild (jumping from 0-60 in a wild way). So today i start the car and the d4 light didnt turn on but the enigne light went on and the speedo still didnt work. Whats my problem?
'95 Honda Accord 4cy Auto 120k miles
Old Aug 17, 2013 | 12:09 PM
dannyrok's Avatar
Default Re: Speedo doesnt work, help!
most likely your speed sensor went out.did your cruise control quit working also?
Old Aug 17, 2013 | 12:27 PM
Mishako129's Avatar
Yes speed sensor, its not a hard fix you can easily do it yourself with the right tools... Also you can buy speed sensors from Ebay for less than $10, that's where I got mine and its been working for about a year now.
Old Aug 17, 2013 | 12:35 PM
bcintron95's Avatar
to be honest my cruise control light on my dash never worked lol, but thanks. Does the speed sensor need to be fixed asap or is it not that serious? im a noobie if you couldnt tell haha.
Old Aug 17, 2013 | 12:37 PM
Mishako129's Avatar
It can make your car shift erratically and cause hard shifting. You should get it fixed.
bcintron95's Avatar
Nice! thanks, im guessing this will stop the d4 from blinking also? Is this something i should fix asap or is it not that serious?
bcintron95's Avatar
Alright will do, thanks again!!
Old Aug 19, 2013 | 07:50 AM
bcintron95's Avatar
so i went to 2 mechanics and they dont have a a computer to get the code from the transmission... smh i need to know if this is really they problem!!!
Old Aug 19, 2013 | 09:01 PM
SIRIUS VTEC's Avatar
SPEEDO DOESN'T WORK
I so badly want to say put on some pants....
But i'll pass and instead tell you that a VSS isn't all that expensive to replace. Try locating a used one or borrowing a friends to see if it makes a difference, then you'll know for sure whether to purchase a new one or not.
In other words, stop going to a mechanic about it...just grab one and test it out. Mechanics are a headache and often give you unnecessary run around and even mislead you as to what the problem really is.
Old Aug 19, 2013 | 09:23 PM
MAD_MIKE's Avatar
MM Gruppe B
Transmission codes are read through the D4 light. Simply jumper the two wire blue diagnostic connector from behind/below the glovebox door. If there are any codes stored the respective warning light CEL/D4/ABS will blink it's respective code.
Not until '96 with OBDII could you get a more detailed code/scanner readout using the OBDII port.
If there is no VSS code it probably is a faulty speedometer.
Old Aug 19, 2013 | 09:31 PM
NZXTInerTia's Avatar
It could always be the circuit board in your speedo going out. But since you have the D4 light I doubt it. I just replaced a circuit today for absolutely free and about 10 minutes of my time. Both are easy to fix.
Old Sep 21, 2013 | 05:31 PM
SlvrJdm's Avatar
Hi there i recently just brought a honda accord 1994 coupe ex 2 door. My speedometer is not working so i brought a vss sensor and replace it but when i drove the car was blinking on d4. Of course i stop the car and open the glove box and use the paperclip to see what is flashing? and it seem to be flashing 4 time. Can anyone help me out? i try every method but the speedometer is still not working.
Old Mar 8, 2014 | 03:14 AM
Known_Offender's Avatar
My 1994 ex speedo/odo malfunctioned, I went salvage with a whole cluster and it turned out that speedo/odo circuit board was bad also. I tried re-soldering with no success. I picked up a third board and that fixed the problem.
ccookie66
Dec 11, 2016 07:01 PM
krysted9354
May 10, 2009 06:20 AM
gooberguy31
Mar 18, 2008 07:38 PM
E Lude U
Aug 1, 2003 10:47 AM
e_r_i_c_
Jun 25, 2003 03:59 PM
