Intermittent Crank/Start Problem
Old Aug 14, 2013 | 05:01 PM
EFS463's Avatar
Default Intermittent Crank/Start Problem
So for awhile now, I have had a starting issue. Sometimes when you get in and turn the key, the relay will click, and the starter solenoid clicks, but the engine will not turn over and it will not start. Usually, if you play with the key back and forth a few times, you can get it to crank and start. The starter was recently replaced by the previous owner, and here is what I have done so far;
Main Relay
Battery
Both Terminal ends
Checked starter wires/cable
Its wierd, sometimes if you hold the key in the crank position, after a few seconds it will start to crank. Anyone have a clue? Would like to get this resolved because other than this issue the car is finally perfect.
Old Aug 14, 2013 | 05:10 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Intermittent Crank/Start Problem
Possibly the contacts within the key tumbler, maybe the ignition switch itself. There are test procedures in the FSM.
GiboGSR
Nov 24, 2017 07:53 AM
seane51
Jan 17, 2014 03:50 PM
dan.
May 19, 2013 02:10 PM
dirtygerman
Jun 17, 2011 07:04 PM
mongo592
Acura TL, RL & ZDX
Nov 9, 2007 06:10 AM
