NEED HELP EK wont start Stock car
Car is a 99 ek stock lx daily driven.
Has 146k
Car wouldnt start so i knew it was getting fuel and then i checked for spark, i put a screw driver into the wire and no spark.
I took the igniter box out of another dizzy i had and swapped it out.
when i went to put the dizzy back i tried to crank the car now it doesnt even crank im assuming i blew a fuse but cant figure out which one.
I checked the back up under the hood its good main relay is good
Also on the cluster when i go to turn the car on the check oil light and the CEL dont illuminate everything else does...
any ideas?
Has 146k
any ideas?
TeamRiskEG6
29
Aug 7, 2008 05:53 AM
