Transmission & Drivetrain Gearboxes, Differentials, Clutches
LSd and clutch problem
Old Aug 10, 2013 | 12:04 PM
NoXqcsMotosport's Avatar
Default LSd and clutch problem
I recently replaced my open Diff with a wavetrac. I am having problems getting the aftermarket passenger drive shaft all the way in to seat it properly it's about a 1/8 of an inch out. I would like to drive it to a shop to have it looked at but the clutch will not disengage. I replaced the clutch while I was working on the trans and bleed the system after it was all back together. Does the drive shaft have any thing with it not going into gear or do i have 2 problems here
thank you for the read
Old Aug 10, 2013 | 12:20 PM
Discosteak's Avatar
Default Re: LSd and clutch problem
so you want to drive the car without the axle fully seated?
Old Aug 10, 2013 | 01:25 PM
I would rather not, but I cant get the passenger side seated and didn't want to have it towed to a shop. but if that is the main reason why it wont go into gear than I will have to
Old Aug 11, 2013 | 02:11 AM
Discosteak's Avatar
have it towed, you can seriously hurt the trans/lsd/axle like that
boostedblue23
Jul 21, 2017 02:02 PM
boostedblue23
Jul 16, 2017 09:12 AM
civicsi401
May 15, 2007 10:49 AM
GSR4U2NV
Oct 9, 2006 07:03 AM
lastpunkinline
Jan 21, 2006 09:26 PM
