Throttle Cable setup on a 90MM Accufab TB
Old Aug 9, 2013 | 03:20 PM
DDTECH's Avatar
Default Throttle Cable setup on a 90MM Accufab TB
Finishing up the new setup and I wanted to see how others were setting up their throttle cable routing to the throttle body and how they were connecting it to the throttle body.
Im going get a Mustang TPS and then i'ma fab up a block off plate for the IACV they have, but from there i'ma need to mount the map and then the whole throttle setup.. hoping to get some help as I've search and goggled and nothing has really come up..
Old Aug 9, 2013 | 06:03 PM
Nikos's Avatar
Default Re: Throttle Cable setup on a 90MM Accufab TB
it would depend on the setup I guess and what kind of manifold you are using as far as mounting the bracket that will hold the cable.
In the past I have always managed to find something that works, some look more pretty than others.
I read a long time ago about using an open end wrench that fits the throttle cable, heating it up and bending it in order to get the angle you need for clearance and fitment. I will try to find a picture for you
Old Aug 11, 2013 | 09:44 AM
DDTECH's Avatar
My problem is, the throttle stop that Accufab uses, doesn't have a placement for the Honda cable. Its ment for a foxbody 5.0 mustang, so it has a nipple and a 1/4 hole.. and mounting the cable on the manifold is fine, its getting it hooked up to the TB and working properly that i'm having trouble with.
Old Aug 11, 2013 | 01:27 PM
Chugger's Avatar
MrParks of fcsrace was running one.
maybe pm him or call fcs tomorrow.
I did a quick search and came up with pics of the fcs integra with an accufab tb on an older post and he was saying what needed to be done but was no mention about cable just a custom linkeage.
hope this helps.
Old Aug 11, 2013 | 03:53 PM
blade0314's Avatar
Im using a accufab 90mm check my build thread out
DDTECH
Aug 13, 2013 02:45 AM
NAallthewayEM1
12
Aug 1, 2009 08:41 PM
neo_
Feb 15, 2009 11:10 AM
NatrualAsp VTEC
Sep 17, 2003 05:19 AM
