b18b1 swap in a 93 del sol si.......what should I look out for???
Old Aug 9, 2013 | 05:00 AM
cody_sandlin's Avatar
Default b18b1 swap in a 93 del sol si.......what should I look out for???
just what it says. the engine in my del sol is out and I've decided to do an ls swap. what all do I need from the ls? engine tranny mounts ecu wiring harness cv axles and what should I look out for?
Old Aug 9, 2013 | 05:11 AM
ManTyme's Avatar
Default Re: b18b1 swap in a 93 del sol si.......what should I look out for???
motor tranny axles half shaft dizzy altenator starter driver mount and rear bracket etc etc
basically everything
you need a DEL SOL VTEC shift linkage the LS linkage is too short for del sol chassis
bladesz42's Avatar
I did this not so long ago. The mounts are the same, you need a dc rear t bracket, your stock harness should work with the motor, DC axles, one of the most important thing on that swap is you need to have del sol vtec shift linkage.
Old Aug 9, 2013 | 05:19 AM
ok the engine in mine is vtec but im not fully sure if the shift linkage is vtec or not
rstewart4328
Feb 10, 2015 05:54 PM
roque-pr
19
Mar 24, 2010 05:21 PM
mikej94civex
Feb 7, 2010 05:40 PM
ubercerealkiller
Mar 30, 2005 03:45 AM
spike
Jul 30, 2004 10:45 AM
