Overheating issue
Old Aug 7, 2013 | 05:56 PM
xSOHC's Avatar
Default Overheating issue
Ok i have a 98 ex that i was told had a leak in the radiator when i bought it. So i bought and installed a new radiator, hoses, thermo and thermo gasket. When i went to replace the thermostat gasket it was all deteriorated and im assuming that was the source of my leak. I still went ahead and replaced the radiator and hoses and thermostat to rule out any other possibilities. After i was done i went to drive the car to see if it was good, and the issue isnt as bad now but its still hotter then it should be. When i went to start my car again i was getting smoke out the exhaust and smelt antifreeze. I do have a check engine light on too so my next thing is guna be to investigate that. Any ideas what could be wrong? Thanks in advance
Old Aug 7, 2013 | 06:28 PM
teamXteg's Avatar
Default Re: Overheating issue
pull the code and post it..
check the oil cap and see if its milky color in the cap
Old Aug 7, 2013 | 08:24 PM
Former User's Avatar
This^
And did you bleed the cooling system?
Old Aug 8, 2013 | 02:14 PM
xSOHC's Avatar
Yes i did bleed the system, there is no milky color in the oil cap. And the code i just pulled is PO171
Old Aug 8, 2013 | 02:19 PM
teamXteg's Avatar
Icon4 Re: Overheating issue
system too rich is the code (45)
but no milky is good
Old Aug 10, 2013 | 01:52 PM
xSOHC's Avatar
Ok so now my car has a searching idle problem on startup. When i turn on the car it rumbles as if its low on gas, and the check engine light blinks. At the same time the rpm is searching between 500-2k. Any help? Thanks a ton
H22Abeast
Oct 26, 2009 06:54 PM
acmoc
Apr 2, 2008 03:03 PM
mickey513
Dec 20, 2004 02:22 AM
CRXSIR1
Jan 12, 2003 05:53 PM
hondafrk
Jul 1, 2002 04:11 AM
