wont start/IAT sensor code
Old Aug 7, 2013 | 11:48 AM
lsdisk0's Avatar
Default wont start/IAT sensor code
alright, so i tucked my wiring, well kinda, got lazy on one side and left it in the engine bay, but anyway, got it all back together. theres 1 harness(not sure where it goes ill describe it later) not connected, but other than that all the sensors are connected where they should be and wired solidly, but im getting still getting a IAT sensor code....
before i checked the codes i tried starting it up and it sounds like something is grounding out and arching, or its just the main relay, not entirely sure on it. it doesnt even try to crank... so i thought maybe my battery is dead, hooked it up to a charger let it do its thing then tried again and still nothing....
the harness described earlier kind of is similar to the oil pressure sensor as it has that little cone-like protective cover thing and it has 2 female isolated connectors...
if i could get help on this ASAP, it would be greatly appreciated...
Old Aug 7, 2013 | 12:06 PM
4drEF's Avatar
Keyboard Humorist
Default Re: wont start/IAT sensor code
Originally Posted by lsdisk0
i tucked my wiring
You answered your own question.
Your wiring is NOT right.
Like the oil pressure sensor?
I think you are describing the water temp switch for radiator fan
Old Aug 7, 2013 | 12:14 PM
lsdisk0's Avatar
yea those, thats it! okay, dont need those because my radiator fan is hooked to a toggle switch lol.
well, okay, i /thought/ i did it right but apparently not lol ya happy?!
anywho, literally all i did was extend the loom and the sensor harnesses....
Old Aug 7, 2013 | 12:30 PM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
well what makes it crank over is the starter and signal wire really.
the sensors are just for when the car runs lol.
go over your starter power wire and especially the signal wire, its female/male connection makes it easy to come off
4drEF's Avatar
Keyboard Humorist
Why bother with the fan on a toggle?
The engine runs best at optimal temp - not too cold and not too hot.
It's much easier to just let the temp switch handle it.
Old Aug 7, 2013 | 12:38 PM
lsdisk0's Avatar
i dont even use my fan, i dont need to. lol. if anything i need the fan to draw heat from the engine to warm up the water.... driving at night my temp plummets to below c lol. the air going through my radiator is enough to keep it at optimal temp. and i got the car with it already wired to a toggle lol...
the wire that goes from the driverside harness to the starter with the little rubber boot?
Old Aug 7, 2013 | 01:28 PM
lsdisk0's Avatar
its not the signal wire and the other two coming to/from the starter werent touched other than disconnecting from the under hood fuse box.
i bypassed all the wiring between the starter and the battery with the ignition on but its still not doing anything?
Old Aug 7, 2013 | 03:07 PM
4drEF's Avatar
Keyboard Humorist
If you for sure have a good battery, then it should have worked.
If you are CERTAIN the battery is good, then;
1. check your grounds. If they all look good, double check by hooking a jumper cable to your NEG post on your battery and hook the other end to the starter or transmission case. Leave the other jumper cable disconnected.
2. If the ground check didn't work, then hook the other jumper cable to the large lug on the starter for power and the other end of the cable to POS battery.
3. If that still didn't work, take length of wire and connect it to POS battery. TOUCH the other end to the tab on the starter that the ignition switch normally goes to.
If that didn't work, replace the starter.
Old Aug 7, 2013 | 09:29 PM
lsdisk0's Avatar
yea... i pulled my starter a tested it because thats what i was doing, i was just jumping it in the car and it would click so i pulled it took it to autozone and yea.... it was the starter -_-
Old Aug 7, 2013 | 11:30 PM
Shit Posts: 15
10 Year Member
ahh, just a coincidence that it went out at the same you tucked the wiring.
Old Aug 8, 2013 | 01:35 PM
lsdisk0's Avatar
lol yea....
went and got a new starter, well a used one from a donor car, and i put it in wired it back up and it doesnt do anything so i just went straight wire from the battery to act as the signal wire and it did nothing. pulled it out and tested it and it spun....
Old Aug 8, 2013 | 01:55 PM
Freemananana's Avatar
lol yea....
Transmission ground. That or your flywheel is SO STRONG that it won't let the starter spin.
Old Aug 13, 2013 | 10:45 AM
lsdisk0's Avatar
wouldnt make sense that it would be my flywheel being "so strong" since it started before i did this; i looked over it yesterday and i did, in fact, miss a ground and i reground it thinking that would be the problem but now i get a whining noise like i have a vacuum leak and it still doesnt start. the started doesnt even try to engage it does just ONE click and nothing more.
Old Aug 13, 2013 | 12:24 PM
lsdisk0's Avatar
Okay, so... new development....
i put an alligator clip onto the male part of the "starter signal sender" and went straight back to my battery and the starter clicks now like its trying as if my battery were just low on power but other than that(putting it "oem") it still does nothing....
Old Aug 14, 2013 | 04:25 AM
Shit Posts: 15
10 Year Member
Maybe your battery does have low power, jump it with a car and see what happens.
Old Aug 14, 2013 | 11:36 AM
lsdisk0's Avatar
you, sir, were correct. buttttt it still wont start. i was watching to make sure my belts n everything were turning and i noticed something on my timing belt and, well... its got a huge rip in it and im thinking it might have jumped and messed up my timing so im gonna get a new belt and hopefully it starts!
Old Aug 14, 2013 | 04:42 PM
lsdisk0's Avatar
soo.... got a new belt threw it on there it would just crank and not turn over so i put my battery to my charger and it was at 60% so i charged it up to 97% and put it back in and now my starter just clicks again and wont try to crank..... wtf is up with this
jonney66
Honda CR-V & Element
May 6, 2014 01:24 PM
2001dxtn
Honda Civic (2001 - 2005)
May 22, 2012 10:46 PM
stockb18c
Oct 2, 2007 08:43 PM
kingSfit
Apr 22, 2006 10:30 AM
wickedxboi
Jul 28, 2002 08:34 AM
