Oil light flashing on 1991 Accord Aero Deck
Old Aug 5, 2013 | 01:23 PM
thefew's Avatar
Icon2 Oil light flashing on 1991 Accord Aero Deck
The oil light is flashing on my 1991 Aero Deck. It has an F22B engine (non-VTEC) that came out of a 1993 Prelude. I replaced the oil pressure sending unit in April 2013 because it was leaking. The oil was a little low, but I added sufficient oil to fix that. The light is still flashing when I drive, and sometimes comes on solid when at idle. What is the best way to test the oil pump? I'd like to make sure that is the problem before I yank it out of the engine.
Old Aug 6, 2013 | 08:34 AM
Lost Again's Avatar
Default Re: Oil light flashing on 1991 Accord Aero Deck
Get a gauge and screw it into the port where the op switch is.
Old Aug 7, 2013 | 03:03 AM
JDMswagSerf's Avatar
Shit Posts: 15
10 Year Member
id try to fix this problem before it gets worse.
Old Sep 25, 2013 | 09:41 AM
thefew's Avatar
A quick update. I removed the oil pressure sending unit and installed an oil pressure test gauge. I measured 30 psi at idle and 80 psi at 3000 rpm with the engine warmed up. Looks like I am taking my oil pressure sending unit in for a warranty exchange.
Old Oct 9, 2013 | 12:34 PM
thefew's Avatar
It's been a couple weeks since I installed the new oil pressure sending unit, and the oil pressure idiot light has not come on once.
Retribution
Apr 1, 2009 06:22 PM
lonewsome
Jan 1, 2009 01:42 PM
shrirag
Apr 11, 2007 09:55 AM
sublimenerd
16
Sep 25, 2006 02:33 AM
LostCRX
Jun 21, 2005 07:12 PM
