cel 67 and bad mpg
OK so first off I purchased this 99 civic ex for a pretty good deal
its in great shape but I noticed a couple things that I need to address
first thing I noticed is that it isnt the original engine Its a D16Y5 with auto tranny
The CEL is 67 I looked it up its a bad cat and I knew something was up because it gets about 24-26 MPG and I notice little black spots on the back of the car (white car) as if its running rich or something of that nature.
Ive reset the ecu several times and can drive about 15-20 miles before same code appears
So heres my quandry IM unsure what cat to get and would like to find a used one if possible
The exhaust is a 2 piece manifold NOT the type that Ive been finding where the car is hooked to the manifold in a vertical position ( I assume its the civic ex exhaust)
after the 2 piece manifold it comes to a small canister with what appears to be an O2 bung
this is located directly below whereabouts the shifter is then it goes for another couple feet and there is another canister.
So..... What model cat do I need and which one is the cat?
thanks bunches
thanks bunches
p2p A92 ah thats the D16Y8 ecu
what ecu do I need?
and I havent done an ignition tune up Ron
first canister
http://imageshack.us/f/51/80b1.jpg/
second canister
http://img12.imageshack.us/img12/2289/z4m7.jpg
what ecu do I need?
first canister
second canister
It is sitting the way it was purchased
not sure how to tell really
http://img708.imageshack.us/img708/2531/9qfv.jpg
dosmastr
May 17, 2012 05:19 AM
thead
Oct 21, 2010 01:55 PM
95 GSR B20VTEC
17
Nov 16, 2008 10:16 AM
