Fouled Plug/Missfire-And- Rough/"Strange idle.
Old Aug 2, 2013 | 06:03 PM
Apple395's Avatar
Default Fouled Plug/Missfire-And- Rough/"Strange idle.
Warm starting is rough (sometimes) (by rough i mean very low and mor shaking, the oil light will turn off then on again for a second)
and idle is roug (always).(when car is warm: )
*cold start=smooth because of 1500-1000 rpm idle)
Idle is 670 but if I am driving and come to a stop it will stall at 1000 for a few seconds and THEN fall back to 670.
I am pretty sure it has to do with cylinder 3 being fouled. (not sure why) I don't know if it is oil, fuel,coolant, or water ( it looks like rust on tip if spark plug)
Please reference picture below-right is cyilder 2-left is cylinder 1 same mileage.
Car has FULL tune up so it's likely not any marine ve related.
I am leaning towards a intake gasket leak (tried spraying with spray bottle, but no evidence of leak-only could spray the top gasket)
Any advice/Tips much appreciated!
Old Aug 2, 2013 | 06:22 PM
fonkernuckle's Avatar
Default Re: Fouled Plug/Missfire-And- Rough/"Strange idle.
maybe a compressiion test or leakdown test might give you better insight onto whats going on in or around cylinder #3
Old Aug 2, 2013 | 06:25 PM
B_Swapped93's Avatar
was just going to say that^^
only other thing I can add clean the IACV just to help out the idle. but something is going on in that cyl. any signs of a leaking HG ?
Old Aug 2, 2013 | 07:11 PM
Yeah B,"looks like rust" on spark plug, first thing came to mind was possible HG leak
Old Aug 2, 2013 | 07:31 PM
Former User's Avatar
Car and engine info?
Get the block test kit from AutoZone to test for exhaust gases in the coolant.
Old Aug 2, 2013 | 07:32 PM
Apple395's Avatar
Thanks for the responses!!
I have not done a leak down/compression test. (But would like to)
I also heard putting a vacume gauge on the brake booster line would basically test for good engine operation. ( is that true)
I tried to diagnose a HG problem...but I have 0 signs...
(NONE OF FOLLOWING: coolant in oil/oil in coolant,water in exhaust...)
Is there a definitive test for HG?!
Old Aug 2, 2013 | 07:37 PM
Apple395's Avatar
Sorry for missing car stats...
99 civic EX (D16Y8)
Engine from 00 (80k miles)
280k on body...
Manual transmission.
I did smell my coolant and it smells like gas/oil...but it could just be due to the hot plastic...
I have good power and no signs of bad HG...engine is less the 100k (and I assume they put a new HG on with new engine...
I would like to look for other fixes before condemning HG...
Old Aug 2, 2013 | 07:39 PM
This^ tests for a blown head gasket. It's a pretty sensitive test.
There's no single test that detects all blown head gaskets. You need to do them all.
Old Aug 2, 2013 | 07:41 PM
do the comp/leakdown can't really move forward until you rule out possibility's.
as for the vacuum gauge yes I'd recommend you get one and see here to better understand it http://www.autospeed.com/cms/A_2393/article.html
definitive way to test i'm not 100% sure but you can test the coolant system pressure which would tell you a bit imo. also are you loosing coolant tho it may be slow depletion ?
Convoy
15
Jan 22, 2020 04:54 PM
DaX
Oct 24, 2018 04:56 AM
Skybow388
Sep 18, 2012 07:51 AM
ejvtec
Jan 26, 2011 07:33 AM
MUGEN_B16CIVIC
Jan 28, 2004 10:30 AM
