del sol wont start wont crank
Old Aug 2, 2013 | 01:54 PM
mooney8289's Avatar
Default del sol wont start wont crank
I have a 93 del sol that just wont crank. About a week ago I finished puuting the car together, as I was putting the finishing touches on it I decided to go to autozone (in my other car) to get some clips for the bumper and some degreaser. when I came back I jacked the car down to get ready for the first test drive and it just didnt want to turn on anymore. I tried to push start it but nothing. Today I went and got the batter, the alternator, and the starter tested and they all passed.... I even tired jumping the starter direct from the battery but I dont even get a spark, after wards I put some jumper cables from my other car to my del sol battery and repeated the manual starter jump but again I didnt even get a spark.... if anyone has any idea what could possibly be the problem PLEASE HELP. ITS DRIVING ME CRAZY
Old Aug 2, 2013 | 04:58 PM
teamXteg's Avatar
Default Re: del sol wont start wont crank
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-how-test-spark-troubleshoot-spark-problems-2919450/
^^ here is a thread for spark problems.. from no spark to weak spark.. hopefully this will help out.
Old Aug 2, 2013 | 05:05 PM
Former User's Avatar
Did you forget to reconnect the G3 transmission ground and/or the G1 battery ground wires?
Old Aug 2, 2013 | 05:07 PM
teamXteg's Avatar
Icon4 Re: del sol wont start wont crank
i wasnt for sure if the ground would stop it from sparking or not thanks for clearing that up for me.. i jus glanced at the thread didnt fully read through it. thanks ron
Old Aug 2, 2013 | 05:14 PM
Yep
Old Aug 2, 2013 | 05:18 PM
teamXteg's Avatar
Yep
now is that any and all grounds?
Old Aug 2, 2013 | 05:22 PM
G1, G3, G101
Old Aug 2, 2013 | 05:25 PM
teamXteg's Avatar
alrighty thank you sir! learn something everyday!
Old Aug 2, 2013 | 09:00 PM
mooney8289's Avatar
https://honda-tech.com/forums/showthread.php?t=2919450
Actually the motor doesnt crank at all... its like its dead
Old Aug 2, 2013 | 09:01 PM
mooney8289's Avatar
Yea iv quadruple checked all the grounds and fuses
Old Aug 2, 2013 | 09:06 PM
mooney8289's Avatar
And also sorry I should have clarified, im not getting a spark from the starters negative terminal when I try to jump it direct from the battery.... as far as the dizzy the motor wont even crank
Old Aug 2, 2013 | 09:07 PM
With a multimeter? Details?
Old Aug 3, 2013 | 12:39 AM
mooney8289's Avatar
No. Just made sure they were connected proper
Old Aug 3, 2013 | 12:54 AM
jbpnoman's Avatar
Get a voltmeter. Test battery voltage across the battery terminals, test for battery voltage at the main starter terminal, and test for battery voltage at the signal wire on the starter with the key turned to ON(III).
Curlybandit
Aug 10, 2013 04:19 PM
nonvtec92
Aug 20, 2010 11:09 AM
ennohohbee
Apr 25, 2010 10:49 AM
jachrist
Feb 5, 2010 10:46 AM
Dominicanstylz02
Jul 25, 2006 04:25 AM
