i had the coilovers only a day
*stock struts*i had them on only a day and was like fuhk this. i dont wana deal with this kind of ride everyday. my gf doesnt have big enough ***** for me to even consider making the sacrifice of having a car that sits low but will most likely give my passangers and i back problems. i went to an alignment place this mourning with the coilovers on and i didnt have enough money. a sign from god i think. so i put the oem springs back on and left the camber kits on. is there another setup i can use to lower my car with an oem feel aka ride. dont use 50$ coilovers i know now. im not looking for performance. just for my car to sit low and to have a smooth ride. the softer the better.
[QUOTE=89ED;49022300..... im not looking for performance. just for my car to sit low and to have a smooth ride. the softer the better.[/QUOTE]
"sit low" and "smooth ride" don't go together in a light car such as the CRX. The best compomise you can do is to cut your stock springs and cut the bottom parts, not the upper part sport.
Also dont know why people are even suggesting cutting oem springs....or any springs for that matter. Lame idea.
Op, save your money...which means, be patient. Do it right.
i got some big time ht members to drop some knowlede in my thread. im honored. its too bad you guys had you nose up high and your thumb in your as. when you decided to kick the little when he was down asking for a hand. i made a rookie mistake. buying cheap parts but maybe a bigger mistake seeking advice from other honda supporters. ill be going with some koni struts and progressive springs or soming with a low spring rate. thank for nothing
CLEARLY this is the fault of your girlfriend.
You better kick her to the curb ASAP!!!
Put your $50 suspension to good use and find a girlfriend with bigger *****.
Little tinnie doorbell bobbies
( o ) ( o )
is NOT acceptable.
Get some real ta-tas and everything will be fine.
Problem solved.
( o ) ( o )
is NOT acceptable.
Problem solved.
Ive given this guy solid advice in other threads regarding d-series engines. Come to find out he doesn't have enough money for an alignment
Looks like i was wasting my time.
Ive given this guy solid advice in other threads regarding d-series engines. Come to find out he doesn't have enough money for an alignment Looks like i was wasting my time.
i had $50 coilovers from ebay when i started...probably was a lil more but same product.
point is, everyone has to begin learning at some point about buying cheap parts. better it be coilovers than that electric supercharger.
I think the point is learning from others mistakes not repeating them. With a 5 second google search you can find the answer to almost anything these days, especially product reviews, so there's really no excuse.
