Bad vibration when accelerating
Old Aug 1, 2013 | 09:14 PM
aemintgsr's Avatar
Default Bad vibration when accelerating
Have a 2000 civic si and when I accelerate in 1st or reverse it shakes rough like wheel hop but at like 2mph speed. I replaced: clutch, axles, half shaft, upper control arms(bushings and ball joint were gone). Only think I can think of are the mounts, but I'm tired of telling my friend of what it could be and wasting his money. Any thoughts would be appreciated thanks
Old Aug 1, 2013 | 09:22 PM
jbpnoman's Avatar
Default Re: Bad vibration when accelerating
You know you can check the mounts before replacing them, right? Pop the hood, have your buddy give it gas in neutral, look for play in the mounts. It's that simple. What clutch and flywheel are on the motor?
Old Aug 2, 2013 | 06:46 AM
aemintgsr's Avatar
Stock flywheel, and some clutch kit from oreilly auto parts that has a heavier duty pressure plate and the clutch disk had smaller springs
Old Aug 2, 2013 | 07:36 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
does it only vibrate when you are letting off the clutch? or is it when the clutch is depressed all the way and you are accelerating?
Old Aug 2, 2013 | 07:45 AM
instrument's Avatar
how are your struts? and your description isnt telling us much. but at like 2mph speed ? wtf does that mean?you got wheel hop at 2mph but.not three?
Old Aug 3, 2013 | 07:20 AM
aemintgsr's Avatar
When I'm letting off the clutch the car jerks really bad
Old Aug 3, 2013 | 07:28 AM
aemintgsr's Avatar
I was trying to describe the speed, same speed when you park a car... Forgot to mention that it started happening when he was getting off the freeway he heard a loud pop and his clutch pedal was dead (would stick to the floor and won't come back up). He pulled over pressed on the pedal couple of times and he managed to drive it to my house and I installed new clutch master cylinder and slave cylinder. Still same vibration
Old Aug 5, 2013 | 08:06 PM
aemintgsr's Avatar
Ttt
Old Aug 5, 2013 | 08:17 PM
B_Swapped93's Avatar
was everything torqued to spec ? axel seated properly ?
Old Aug 7, 2013 | 02:05 PM
aemintgsr's Avatar
Yea sir
Old Oct 13, 2013 | 03:44 PM
gunadvocate79's Avatar
I'm having this same issue with my 2000 Honda Ex. Everything mechanical is completely stock and original part. Car has roughly 160,000 miles. Replaced the plugs, wires, dist. cap and button, and fuel filter all within the last year. Only does the vibrating when accelerating from dead stop. Maybe a slight difference in the intensity with the a/c on. Once moving, issue is gone. Had thoughts that the clutch plate is probably warped but wanted to get a second or third or fourth opinion before dropping the transmission to replace. Any suggestions would be appreciated.
Old Oct 13, 2013 | 08:49 PM
Koko4's Avatar
I'm having a VERY similar issue, but mine happens under acceleration during a load (uphill / hard acceleration). I've replaced axles, motor mounts / transmission mount / shifter stabilizer bushings, all trying to fix this problem. I noticed that if I am accelerating and this vibration is happening, and if I press in the clutch then release it again (effectively putting the clutch against the flywheel in a different spot), it will stop or do it noticeable less for the rest of the acceleration. Would that indicate a warped flywheel? You might want to try doing the same thing on yours - just push the clutch in and then release when the symptoms are happening, and see if that makes it any better. Could indicate the same problem I'm having.
Old Oct 18, 2013 | 03:15 PM
I've noticed that if I ride the clutch out extremely slow, I can minimize the jumpiness. I've been driving this thing since 01'. I find it hard to believe that all of a sudden, I don't know how to drive a clutch.
Old Oct 18, 2013 | 05:57 PM
jdmh22eg2's Avatar
flywheel shudder from sounds of it. flywheel has hot spots or high/low spota
Old Oct 19, 2013 | 01:50 AM
DylanGSR_eh9's Avatar
I had the same problem but Idk yours sounds different, i replaced my axles and front rotors, also motor and tranny mounts and problem solved ( btw motor mounts were completely gone!)
Old Oct 19, 2013 | 02:20 AM
azzazel_9's Avatar
Sounds like flywheel to me.
Old Oct 21, 2013 | 02:20 AM
Solster's Avatar
sounds like you didn't get your fly wheel resurfaced or it was surfaced out of spec and the fly wheel is now junk.
also did you remember to wash the pressure plat in HOT soapy water to get the cosmoleen and or packing grease off?
Did you get grease or greasy finger prints all over clutch disc and or pressure plate surface?
globy123
56
Sep 16, 2018 05:53 AM
Cashmoney061596
Feb 7, 2014 12:28 PM
viper_boy403
Transmission & Drivetrain
Nov 21, 2011 03:01 PM
ivan93egreppin210
Sep 12, 2009 07:01 PM
b18c5-EM1
10
Aug 12, 2004 06:39 AM
