DRL
My drl are not working fuse keeps blowing. I took the drl module out and it looked like there was 1 bad solder point, but still not working. I want to take a look at the relay. I believe its behind the glove comp. Do i have to take the glove comp off the reach it? Also what does it look like?
From the FAQ's...
Those should help. If the module isn't the issue, you have a short you'll need to locate and repair.
Edit:
Even better - https://honda-tech.com/forums/showth...2#post49003192
Edit:
ClubRX
Sep 30, 2007 05:07 PM
