Vibrations
ok, i havent been with my car for a while now... (need new liscense plates) and when i went to start the motor up for a bit, the motor started without a problem... BUT, the whole car was vibrating like a massive *****.
i thought that the car was having a little trouble cuz the weather was gettin a little colder, so i left it to get warm.
but even after my motor temp was good, my car STILL vibrates... and also when i press the brakes, the car sounds like its gonna die... the rpm dips down to like 600..... wth is goin on?? help!~
My vote's for the motor mounts on the vibrating... but I have no idea.
I have a vibration problem, too, though so I'm gonna just hop on here. There's a bad rattle between the metal and plastic panel next to the back driver's side seat. I had the panel off and had a friend look at it while I drove, but he couldn't figure it out. I know at least one other person has had this problem considering the reputation these cars have with vibrations, so can anyone help?
I have hasport mounts and when I start the car when it's really cold it vibrates a whole bunch... i hear ALL my rattles.
after it warms up.. not just motor but tranny oil and suspension does some flexing from driving it becomes a normal car again.
Everything on your car is cold and stiff.. bushings, motormounts...
My suggestion, run it for a while or go in a 100 mile road trip real quick and see how it is then.
how does a ***** feel like when it's vibrating?
never had the pleasure of meeting one
j/p
it happens to my rex when i don't drive it for a couple of days. ihope its normal
j/pit happens to my rex when i don't drive it for a couple of days. ihope its normal
ur engine idle its too low.. try puttign the idle a little higher.... close to 750-800 rpms..... if ur timing its stock u can just advance it a tiny bit,... if not p0lay with the idle nut on the trotle body....oh but before reset ur ecu t see if it helps....
i can definitly feel it on the steering wheel... and my seat... its annoying...
ARGH..
i guess i'll try JDM EF9's tip... and also check the motor mounts thanks guys.
A lot of vibration can also be caused when the polyurethane mount/inserts/bushings are used. Polyurethane is more rigid than rubber hence the vibrations.
thanks for the suggestions
T_bones
Sep 5, 2005 03:11 PM
pootie.teng
24
Apr 19, 2004 01:08 PM
