did i fill up too much oil??
i followed this chart to do oil change on my 04 ex but on the dip stick my oil is about inch above to top mark....
i put about 4 qt of oil in totall..
Did i overfill ?? should i leave it alone or take some out..
the exact amount to change during an oil change for the EX motor is 3.7qt. this includes the capacity of a new and dry oil filter as well. i usually do 3.75qt and this fills it right to the max fill dot on the dipstick after i let the motor for for a minute. 4qt is too much. drain some into a clean oil pan and re-add necessary.
i noticed that oil is about a inch above the top mark when egnine is cold. but wen i warm the engine and checked for oil again its only abt a cm above the top mark.. should i still be worried?
mcd7
16
Jun 6, 2011 09:33 PM
tensai717
Dec 9, 2001 03:49 PM
