00 em1 cranks but no start like if the compression went out over night
Old Jul 30, 2013 | 01:48 AM
prelude2.2's Avatar
Default 00 em1 cranks but no start like if the compression went out over night
ok so i have a 00 si i used to have a itr took it out put my oem b16 back in as i try to crank it up i get nothing all i hear is the starter turning the motor but no explosion/compressed crank hope that makes sence im getting spark and fuel i can see the crank puller spin as well as my cam gears so its going this motor ran perfect before any ideas??
Old Jul 30, 2013 | 02:41 AM
instrument's Avatar
Default Re: 00 em1 cranks but no start like if the compression went out over night
checked firing order and timing?
Old Jul 30, 2013 | 05:17 AM
black97civic's Avatar
Is your intake free of debri? Sounds dumb but if you have spark and fuel i would think it would do something. Maybe push your gas pedal down when cranking?
Old Jul 30, 2013 | 05:20 AM
Also check fuel pressure if you have a way. Maybe something got in your fuel rail. Did you put the original ecu back in?
Old Jul 30, 2013 | 05:45 AM
HondaPartsHero's Avatar
Technical Hero
Color of spark?
How did you check fuel?
Check compression?
Old Jul 30, 2013 | 10:48 AM
prelude2.2's Avatar
ill try holding the gas pedal but I checked fuel by pulling injectors out and all squirt gas ill check timing and update with any results could a bad crank position sensor cause this cranking sound problem I took that sensor off then put it back on I heard if u do that u can mess things up
Old Jul 30, 2013 | 11:49 AM
teamXteg's Avatar
Icon4 Re: 00 em1 cranks but no start like if the compression went out over night
Originally Posted by HondaPartsHero
Color of spark?
Check compression?
Old Jul 30, 2013 | 12:59 PM
prelude2.2's Avatar
btw spark is blue could the firing order cause the motor to sound like flat dull crank sound
Old Jul 30, 2013 | 01:48 PM
B_Swapped93's Avatar
waiting for timing check...then compression. are you getting fuel ? (confirmed plugs wet)
Old Jul 30, 2013 | 11:37 PM
prelude2.2's Avatar
plugs are wett I need to get a compression tester nd timing is good
Old Jul 30, 2013 | 11:39 PM
prelude2.2's Avatar
btw forgot to say in description car turned on once drove up street turned it off and now it wont crank back up
MitchHamilton
15
Oct 25, 2016 05:00 AM
WifesVTEC
Jan 31, 2011 04:46 PM
d16z6civic811
Dec 7, 2010 07:06 PM
hollowman8904
Jan 7, 2009 08:59 PM
draw
20
Nov 22, 2004 08:33 AM
