Is a Walbro fuel pump needed?
I plan on turboing my LS, running around 12 psi on stock internals, 450cc injectors, with a Hondata fuel management. I was reading on the hondata site, and I came under the impression that with Hondata, if you have bigger injectors, higher pressure fuel pumps were not needed. Is this the case? TIA
http://www.hondata.com/techfuelpump.html
your title says water pump. A larger fuel pump with large injectors isn't necessary, but recomended.
the high pressure pump will only be needed if you are running a fmu setup. if you are using larger injectors with the hondata, smc or afc, the regular 255lph pump will be more than enough.
[Modified by fire7882, 1:19 PM 10/25/2002]
turbolsvtecej1
Sep 7, 2014 04:06 PM
HybridCoupe
Jul 6, 2002 04:44 AM
