people with lightened factory flywheels
Old Oct 24, 2002 | 09:49 PM
Louie B.'s Avatar
Default people with lightened factory flywheels
Could someone please post a pic of their flywheel so I can see where the material was removed from? I have access to a metal lathe (sp?) and someone who knows how to use it, but he's never lightened a flywheel before.
Also, does anyone know if there's a difference in stock weight between the 88-91 flywheel and the 92-95? The flywheel that's about to go under the knife is from a '95 Si, and I'm planning on shaving apx 4 lbs off, but if that only takes it down to 88-91 weight, I might as well go a little further.
Don't worry, I plan to get the flywheel balanced and surfaced after I'm done hacking it up. And I'll be running it on a mostly stock NA D16A6, so I shouldn't have any shattering problems. Besides, if it does shatter, it's the passenger that gets hit, not me.
Old Oct 24, 2002 | 10:19 PM
gtcali's Avatar
Default Re: people with lightened factory flywheels (thumpu77)
No pic, but all that extra metal on the motor's side of the fly wheel. Kinda like resurfacing the back side of the fly wheel.
Old Oct 24, 2002 | 10:31 PM
Louie B.'s Avatar
Default Re: people with lightened factory flywheels (gtcali)
So, where the stock flywheel gets thicker as it gets to the outside, grind all of that down so it's the same thickness all the way out?
Old Oct 24, 2002 | 10:44 PM
.ShawnD.'s Avatar
pretty much .. but i hope your not trying to do it your self??.. just pay someone 50 bones to have it done .. that way its not of balanced
Old Oct 25, 2002 | 06:50 AM
Louie B.'s Avatar
Default Re: people with lightened factory flywheels (.:s h a w n D:.)
None of the shops around here are willing to do it for me, The clossest shop I can find is 50 miles away and they want $100.00 + $35.00 to balance it.
The guy that's doing it for me knows how to use the lathe, and knows how to keep things in balance. Plus I plan to get it re - balanced when I'm done
Old Oct 25, 2002 | 06:54 AM
Louie B.'s Avatar
I got a pic from a different board (special thanks to Mista Bone from the D-series board for this one) I thought I'd go ahead and post it on here for anyone that does a search and finds this thread in the future:
Old Oct 25, 2002 | 07:03 AM
.ShawnD.'s Avatar
alright cool deal .. i thought you were about to just break out the dremel.. haha as long as you have it balanced your straight good luck man
Old Oct 25, 2002 | 08:16 AM
JOEY F.'s Avatar
Yah....just shave off the material on the outer parts of the f.wheel...you want some material left near the crank and stuff. ( for added strength) We did mine off of a brake lathe and we managed to shave it down to 11.8 lbs with out breaking ne thing....got it balanced and its been in mah car fer 30k now. Damn good for 80 bucks. Its not a Jun Ultra light but itll do
Old Oct 25, 2002 | 08:51 AM
keithv's Avatar
Default Re: people with lightened factory flywheels (josEF)
take off as much weight as you can from the furtherest point away from the center. i was able to get a 1/4" W x 1" L band taken off my stock flywheel. not sure how much weight it was, but it had to help.
Do-Work
21
Jul 8, 2009 07:06 PM
RaceMyGhost
Jul 4, 2005 10:45 PM
SuicideSlide
Sep 7, 2003 09:55 AM
B16CivicHB
Jan 28, 2002 06:31 AM
JM Performance
Oct 2, 2001 11:34 PM
