1993 accord fuel filter- epic fail
Old Jul 27, 2013 | 11:11 AM
Aseegz's Avatar
Default 1993 accord fuel filter- epic fail
Hey all, so im trying to change my fuel filter, and I couldn't really find any videos or good how to's. The one's I found make it seem very easy. I found this to be wrong lol. How the hell do you get that big black box( master fuel relay? ) out of the way? there are connections on it that cant be taken out( like the red bungee cord looking thing) . And also, I remember in my jetta I would take out the fuel fuse, do I do this in the accord? Do I loosen the bolt on the fuel line to relieve pressure ? A step by step would be awesome. Thanks all.
Also found 2 loose wires when I took out my air intake.Any chance anyone can identify ?
Old Jul 27, 2013 | 08:24 PM
DeadlockRiff's Avatar
Default Re: 1993 accord fuel filter- epic fail
Those wires aren't factory.
To do this job you'll need a crows foot wrench (to hold the fuel fitler) with a decently sized extension and a spanner wrench to break the nut loose from underneath the car. (youll be standing/laying directly underneath the drivers seat.)
Then from there you will have to do some left hand gymnastics to get the banjo free.
After that you will need to remove the filter bracket (I think they were 12mm heads) with what should be only two bolts if i rememeber correctly.
The hardest part is getting the banjo bolt and the copper washers all back on without dropping them 50 times on the floor. Reverse of removal is the installation of course.
The factory service manual's method requires you to drain the fluids of the powersteering system and moving the lines out of the way and a few other things I cannot recall.
To disable the fuel pump, find the relay, the fuse, or just unbolt the ground.
Old Jul 27, 2013 | 09:44 PM
Aseegz's Avatar
Thanks deadlock, isn't the fuel filter on the passengers side if looking at the hood.
What do I need to go under car for ? I got as far as taking the banjo off and putting it all back once I realized I wasn't sure what I was doing lol.
Would like to know what those wires are
Old Jul 27, 2013 | 10:09 PM
NZXTInerTia's Avatar
Absolutely not. That's the charcoal canister lol. The fuel filter is between the subframe and the power steering rack on the drivers side chassis.
Old Jul 27, 2013 | 11:22 PM
holmesnmanny's Avatar
OP, you don't have a '93 Accord. If you did, you wouldn't be asking all these questions.
You just need a set of crows feet. I've never done one on a 5th gen accord but I know that with a set of crows feet and a crescent wrench and a set of flare wrenches it's doable without moving anything out of the way.
Old Jul 28, 2013 | 07:19 AM
You need to go underneath so you can hold the filter with the crows feet as you break the nut with the spanner. You cannot access these two from the top without pulling out an uncountable number of parts.
If you don't have the second wrench on there you will begin bend and twist components. At the worst you can twist your fuel line and you can go have fun with that.
As I was saying, you'll have to follow that conduit and look for that wires reappearance later down the line. It isn't a wire that the car had from the factory.
Old Jul 28, 2013 | 12:16 PM
leflore's Avatar
Is the 93 that much different from my 1992 accord?(2.2 manual). get to mine from the top on the passenger side.
Old Jul 28, 2013 | 12:36 PM
Judging from his questions he has a 5th gen and not a 4th gen.
OP can you post a picture of said vehicle?
Old Jul 28, 2013 | 10:20 PM
Aseegz's Avatar
I can post a picture of it. It REALLY looks to me like it's on the passenger side like leflore said. The guides I saw never said anything about having to go under the car, Im starting to get scared lol, thought it was a easy job.
So I found out the wires were after market, My buddy suspects from a old fog light set up. But nonetheless, it was spliced into the headlight wire. So we took it all out, re soldered the wire to the original and shrink taped it. So that's good.
This is the video I referenced for the fuel filter.
Old Jul 28, 2013 | 10:41 PM
if that's the same setup as your car then you indeed have a '93 and you don't even need crows feet...you just need a 14mm flare wrench and a crescent wrench and you're good to go...you're probably trying to use an opened ended wrench on that fuel bolt which can be disastrous as you will strip it in no time.
get a flare wrench set and you'll have it replaced in no time
Old Jul 29, 2013 | 10:42 AM
Aseegz's Avatar
Thanks holmes, I appreciate cha!
1999accord
Apr 6, 2022 05:12 AM
burnhamr
Feb 27, 2009 12:27 PM
Hando
Mar 17, 2007 08:31 AM
F22a1stick
Oct 16, 2005 06:17 PM
Orig
Oct 28, 2002 05:09 AM
