car has power but will not crank
Old Jul 24, 2013 | 04:10 PM
natemfhunter's Avatar
Default car has power but will not crank
hello. I have a standard 1994 Honda civic hatchback cx. I was driving my car and parked it. when I returned it would not start. I have looked at it myself and am puzzled. I used a volt ohm meter and tested every possible fuse, and they are all good. when I turn my key to the on position, there is power, when I turn it further to the start position there is nothing and it will NOT attempt to crank. I jumped the started to start the car and it runs for only a few seconds and then it looses fuel pressure. I have to disconnect the battery and reconnect it again for the fuel pump to kick back on. any ideas? all help will be very much appreciated. thank you
Old Jul 24, 2013 | 04:11 PM
Default Re: car has power but will not crank
if there are any further questions, please feel free to ask as all questions will narrow down the problem. thank you
Old Jul 28, 2013 | 09:36 AM
Phoenix5's Avatar
Have you checked your relays?
look for any wires that could be grounding to the body.
Sounds like your electrical system is not getting power, specifically the ecm
Old Jul 28, 2013 | 11:45 AM
yes. I have checked the relays, they are good. also I have checked to see if there are any open wires, there are not. so I do not believe that anything is grounding out to the body.
Old Jul 28, 2013 | 11:49 AM
black97civic's Avatar
Did you check the voltage on the battery?
Old Jul 28, 2013 | 12:07 PM
UK-Kev's Avatar
Hi, Have you checked the ignition switch because Honda have issued recalls in the past concerning this item.
Rgs. Kev
Old Jul 28, 2013 | 04:27 PM
teamXteg's Avatar
Icon4 Re: car has power but will not crank
so does the fuel pump normally prime? or is it kinda hit and miss?
Old Jul 28, 2013 | 04:31 PM
instrument's Avatar
the first part sounds like your clutch engagement switch. but the fuel shutting off seems like a seperate issue.
Old Jul 29, 2013 | 04:08 AM
The voltage on the battery is good and before this issue the pump has always primed. I googled the clutch. I cant find where a rubber boot is suppose to be.
Jokester
Apr 13, 2010 01:13 PM
kin413
Jun 15, 2007 10:23 AM
SilverGT
Dec 2, 2006 03:12 PM
rexheadb16a
Jun 4, 2003 05:30 PM
sparq
Apr 20, 2003 04:49 PM
