conversion harness ? dpfi-mpfi
I have seen a ton of pin outs and wire diagrams just wondering if I bought the obd1 ecu harness can I get a engine harness made and drop my swap right in? I dont have the time 2 go chasing wires and running wires 2 make it clean.
The OBD1 ECU harness runs all over behind the dash.
It's a boat ton more work than you are thinking.
Since nobody sells what you are asking for, you would be looking for a custom harness which would be stupid expensive.
Making DPFI to MPFI is REALLY REALLY EASY.
You can then check out places like RYWIRE for a tucked harness if you are looking for something clean for your OBD1 change-over.
invisible
Nov 19, 2006 09:23 AM
jisu009
Mar 26, 2004 01:13 PM
