1998 Civic EX 4Dr Auto ABS 51 Trouble Code Problem! Help!
Old Jul 23, 2013 | 08:07 PM
Reaccion's Avatar
Default 1998 Civic EX 4Dr Auto ABS 51 Trouble Code Problem! Help!
I am having a problem with my 1998 Honda Civic EX 4 door automatic ABS system. I was installing an amplifier for my car. I removed the center console and a couple other plastic parts to run the wiring to the trunk. After finishing my installation, everything was ready expect for the ABS system which lights up after my Civic is moving and not idling. I checked all the fuses and even changed the Abs relay directly from Honda but I got nothing. I did my research and learned how to pull out the ABS code which was the 51 code. This ABS code refers to the Motor Lock. This ABS light drives me crazy!! Please let me know guys any suggestions! Thanks!
Old Jul 23, 2013 | 08:21 PM
Former User's Avatar
Default Re: 1998 Civic EX 4Dr Auto ABS 51 Trouble Code Problem! Help!
Why did you replace the relay? Have you cleared the code from the ABS control unit to see if the code returns?
https://honda-tech.com/forums/showpo...06&postcount=5
Old Jul 23, 2013 | 08:26 PM
Reaccion's Avatar
Well, I checked it and I did not find positive voltage going to the ABS motor. Yes, I have cleared the code. However, the code comes right back after my car starts moving. Very nice link! Thanks!
Old Jul 23, 2013 | 08:29 PM
How did you clear the code?
Old Jul 24, 2013 | 03:31 AM
Reaccion's Avatar
I used the paper clip and brake pedal procedure.
Old Jul 24, 2013 | 05:45 AM
Check the 7.5A MTR CHECK fuse and the 40A Pump Motor fuse in the ABS fuse box under the hood.
Old Jul 24, 2013 | 03:06 PM
Reaccion's Avatar
Very nice diagram. Yes, I did check those fuses. In fact, I checked all of them fuses. They were all in great working order.
This is very confusing. Everything points out to the motor lock.
Old Jul 24, 2013 | 03:41 PM
Old Jul 25, 2013 | 03:39 AM
Reaccion's Avatar
Thank you RonJ@HT, I am going to use this to troubleshoot and then I will let you know.
scottyyhz
Honda CR-V & Element
Dec 30, 2014 04:46 PM
piers.tremlett
Suspension & Brakes
Aug 10, 2014 02:59 AM
tjwebber17
Suspension & Brakes
Jul 2, 2011 10:15 AM
mikey1968
Nov 9, 2010 07:10 AM
