f22a/f23a hybrid CB7
well due to some unfortunate events(balance shaft seal walked out) my engine let go. so i've started a new build and it is almost complete. my camshaft, new gear and rocker spacers will be in on Thursday, installed Friday and if a3ll goes well, tuned on Saturday.
K&N filter
BLOX 4" velocity stack
AEM BB6 V2 SRI
Maxbore 70mm>64mm H23vtec throttle body
Skunk2 Pro series V2 H22 intake manifold
OEM RDX 410cc injectors
AEM adjustable FPR set at 40psi
PT3 (F22A) cylinder head milled .020" (bumps compression to 9.7:1)
Bisimoto level 2 regrind
Bisimoto Pro valve springs
Bisimoto billet aluminum rocker spacers
Bisimoto cam gear
JDM F23A short block
Bisimoto V2 4-1 header
Ktellar 2.5" exhaust piping kit
Vibrant super quiet resonator
Xforce varex dual tip muffler
goals: 180whp, 165wtq
this is my old setup
1992 honda accord lx coupe 5spd
full interior with functioning a/c and cruise
K&N filter
AEM BB6 V2 SRI
Professional Products 68mm throttle body
Bosch #42 injector (garbage)
Web Camshafts level 1 regrind
Hayame cam gear
tuned on hondata
h23 m2s4 trans.
not a racecar, doesn't run 10's, isnt a K,B or an H and only runs 14.7's consistently, but is the most fun ive had owning a car. local cars are about 75% civics, 15% integras and about 95% of each are 16-15.5 sec cars so i have the fun of alot of shocked faces stoplight to stoplight, lol.
K&N filter
AEM BB6 V2 SRI
Bisimoto cam gear
K&N filter
AEM BB6 V2 SRI
Hayame cam gear
tuned on hondata
h23 m2s4 trans.
I had a similar setup in my Accord a few years back. It wasn't ideal, but it worked well enough and made decent power for a stock F23 short block and F23 head. I'm sure your setup will meet your goals. Looking forward to an update!
- F23A1 Engine, stock bottom end with ~42k miles
- Mild DIY port work on the head
- Milled head (.030", calculates to ~9.9-10.0cr)
- Bisimoto Level 2 Cam
- Bisimoto Pro Valve Springs
- Bisimoto Pro Retainers
- H23 Intake Manifold with custom Adapter Plate
- AEM Cam Gear with bolt upgrade
- P61 ECU (92-93 GSR) chipped and tuned with eCtune
- AEM CAI (hacked up)
- eBay 4-2-1 header with 2.5" collector mod
- 2.5" Mandrel bent exhaust
- Vibrant Flat Black muffler
- Vibrant Ultra Quiet Resonator
- 12lb Lightened OE Flywheel
- LSD Motorsports 6-Puck Clutch
- Custom geared M2S4 5-speed transmission
- Energy Suspension Poly motor mount inserts
- ARP Head studs
Awesome! Really looking forward to see how you progress over what you currently have. How come you didn't stick with that modified Vibrant header?(still have it?)
If you're willing to donate me that VTEC head, I'll take it.
If you want it its for sale with the intake manifold. $150 plus shipping. It's a good cylinder head. It's off now, I took it to the machine shop and had it pressure tested. The engine only had 24k miles.
Curious, how much did that 4-1 manifold cost you? They're stupid expensive, always interesting to see someone actually running one. The honestly look sweet, somewhat like a turbo ram horn.
You will have to fabricate it yourself, have someone fabricate one for you or pay the $800+ for the overrated F22 market brand. I'll be making my own 304SS 4-1 w/a Burns Stainless merge collector and megaphone for under $600. That's materials and consumables (welding filler and gas)
Congrats! Looks like you easily met your goal and then some. Did you have the opportunity to make some cam adjustments on the dyno? I'm curious why the Bisi level 2 cam regrinds don't carry torque higher than they do. What are the future plans for this?
