b18c5 in eg--->running weak??
i have a 97 b18c5 in a my 93 si. the only mods are intake and skunk2 catback. i have a chipped p28 with a skunk2 program and it doesnt seem to be running strong. ive used a p28 mugen program also, it was a little stronger at the top end. but it still seems slow. i drove a friends stock jdm b18c in eg yesterday and his seems alot faster. are the programs iam using no good?
arent all civic and integra injectors same?? 240?
timing has been checked. but iam using the factory si fuel pump with the itr injectors. ill try the fuel pump and see how that goes. ill let you all know how i make out
check for codes. check ignition timing. make sure you arent off a tooth. fuel pressure with hose connected should be between 40-45. should help.
AdrianArteaga98
20
Apr 17, 2017 06:54 PM
96accordsir
16
Jan 11, 2009 08:51 PM
