beefed up the hardware
Old Jul 22, 2013 | 08:36 PM
89ED's Avatar
Default beefed up the hardware
i bought a egay camber kit. then went to kingbolt in covina CA and wanted to beef up the hardware. the allen head hardware was stamped 12.9 strength. it was nickle plated which he said was weird. have gave me 10.9 strength hardware to use. i ask why a lower strength? he said really high strength stuff doesnt give or bend and when it gives it snaps. 10.9 will do that. sounds logical. he said i would be suprised on what strength bolts they use to build large buildings.
Old Jul 23, 2013 | 02:55 PM
89ED's Avatar
Default Re: beefed up the hardware
bmp
Old Jul 23, 2013 | 02:57 PM
YellowBacteria1's Avatar
thanks for that insightful post.
Now I can sleep at night, knowing you have the right hardware for the yob.
Old Jul 23, 2013 | 03:23 PM
4drEF's Avatar
Keyboard Humorist
What was wrong with the 12.9 screws in the first place?
You didn't need to change them out - the Kingbolt guy played you.
Old Jul 23, 2013 | 06:37 PM
F22Master's Avatar
I didnt trust those bolts either, but I went a step further.
I got these - Metric Flange-Head Class 12.9 Alloy Steel M6x20mm
Part Number 92235A240 @ http://www.mcmaster.com/#
$4 for 10 of them.
The tensile and shear strength of the bolts isnt the only thing you need to worry about with adjustable camber arms. I have seen the top of the arm, the plate that the bolt heads sit on, get torn through right where the bolt head was. The bolts were still fine. So you not only need good bolts, you need to spread out the load with a larger surface area. But because the EF arms usually have the raised section in the top-center of the arm, regular washers wont fit. The washers attached to these ^^^ bolts just barely fit. And they add enough surface area to at least give me some more peace of mind.
Old Jul 23, 2013 | 07:15 PM
89ED's Avatar
well i didnt buy these camber control arms so i could put them to the test. my d15b2 is never going to see redline or a moutain road. i bought them so when i get the alignment the camber is adjustable. thats all. i went to kingbolt for the comfort of knowing the bolts i was using was the strength it was stamped with.
i had no faith in the bolts it came with. i feel i brought the camber kit from an egay quality to an ebay quality.
Old Jul 25, 2013 | 02:52 PM
daveb91's Avatar
Front control arm camber kit?? The bolts would be the last thing I would be worried about.
Old Jul 25, 2013 | 08:34 PM
89ED's Avatar
meeaning?
Old Jul 27, 2013 | 06:55 PM
daveb91's Avatar
Ball joints are ****...
Old Jul 27, 2013 | 10:41 PM
89ED's Avatar
i was thinking the same thing
do you think i should buy some from autozone and press them in ?
throwing away the old ones
Old Jul 27, 2013 | 10:45 PM
NZXTInerTia's Avatar
Good luck pressing ball joints in and out of your UCA's. Its damn near impossible without bending the crap out of them.
Old Jul 27, 2013 | 11:46 PM
89ED's Avatar
well camber kit so. i can get the ball joint away from the control arm itself. and then a 5 ton press. what do you think.
Old Jul 28, 2013 | 12:58 AM
I think you're going to bend the **** out of your UCA like myself and many others have done. Your only real option unless you're a wizard is to get an entire adjustable UCA. Ebay camber kits are junk and I think its mighty ignorant that you're trusting your life to one and of all the drivers around you.
Old Jul 28, 2013 | 07:02 AM
F22Master's Avatar
...that is what he has...
Old Jul 28, 2013 | 11:25 AM
89ED's Avatar
and like i said in a post before. i bought the camber kit not for performance but merely to have camber adjustable when i go and get a alignment.
Old Jul 28, 2013 | 11:27 AM
Riceburner247's Avatar
Are you referring to the stock UCA?
Old Jul 28, 2013 | 08:45 PM
89ED's Avatar
CMON BRO!
zzzzzsi
Aug 28, 2006 07:10 PM
P@@RB@Y
Welding / Fabrication
Dec 25, 2005 09:12 PM
jerBEAR
Nov 12, 2005 10:56 PM
lil k
May 19, 2003 12:22 AM
.brad
Sep 9, 2002 11:41 AM
