Got darton sleeves,and oil in coolant help
Hello i have a problem i have a B18 turbo with darton sleeves.
I went a few days ago on the dyno and i got 700HP on the crankshaft.That's about 613 HP on the wheels, i have 630 Nw of torgue.
I pulled two runs on the street and everything was fine the boost was nice so i was happy.Got the car on the trailer and went home, put the car in the grage.the next day i wanted to check my fluids and saw that i had oil in my coolant.Can any one tell me what the problem is.
I'm scared that my sleeves dropped,or is the gasket of my head that is leaking.Cause if my sleeves dropped i have a huge problem what means that my whole has to come a part.
Hope that somebody had the same problem and can tell what it is.
specs of the engine. B18 turbo
JE pistons 8.5:1
Eagle rods
81.5 darton sleeves
Crankshaft balanced
ALC bearings
ARP studs bolted with 130 Nw ( for head lift)
Brian crower camshafts
Supertech valves and retainers
Golden eagle fuel rail
2200 cc of bosch injectors
Holset hx super 40 turbo charger
Twin scroll topmount manifold
2 Tial 44mm waste gates
Brian crower adjustable cam gears
JE pistons 8.5:1
Eagle rods
81.5 darton sleeves
Crankshaft balanced
ALC bearings
Best to open it up and check it out. If I had a lot invested into my motor I would want to know wtf! You could start with the gasket and try that but if you think a sleeve dropped and you want a warm and fuzzy then it is best to get eyes on.
I would do a leakdown test on the engine, up to temp ( or as close as you feel ) with the radiator cap off with a spill-free funnel. Then you can tell if its the headgasket or not with out tearing down the motor. If you have bubbles on witch ever cylinder you are on then you have found your problem. If none of the perduce bubbles the start looking else where.
I had a Darton sink. Blew head gasket right away. N when I pull head u could barely feel the lip where it dropped. So wasnt much. But head gasket blew out hard lol. So mayb ur lucky. But pull it apart . As stated.
You didn't need to make two threads.
Do a comp/leak down.... if its bad pull the motor apart and inspect it.
"Barely feel" when it comes to racing engines is A LOT.
Stop ***** footing around it and just do it. You have a problem which involves at minimum taking the head off anyway since you've got oil in the coolant.
Is there a lot of oil, or just a slight film? Does the oil in the oil pan look like a chocolate shake? Is the radiator being reused from a previous build that blew up?
If you still have good compression in all 4 cylinders then its likely NOT a dropped sleeve. A simple compression test and leak down will tell you that info righ away. No need to pull apart the engine if it passes a leak down and compression test.
