240 whp / 190 tq 28rs at 16psi Z6
Hey guys,
Wondering if this was a usual acceptable number for a z6, wiseco 75,5mm, eagle combination with a 2860rs, wg44 .72 a/r. IAT of 77 degrees. On 91 pump
Thanks
Thanks
That's pretty low assuming you're revving past 6k. You should be making an absolute minimum of 260/200 at 16psi on a bad day. Unless you're at a higher altitude then 240 might be acceptable.
One of the following is crap, in order of likelihood:
Inefficient turbo, bad tune, intake flow restriction, exhaust restriction, incorrect dyno reading, incorrect boost reading, excessive drag, compression loss, or witchcraft.
Post your dyno graph.
Comparing dyno numbers is useless. My car put down 260 on a mainline and 297 on a dynojet. Track times are a way better way of seeing if your car is doing what it should.
Civic_95_Si
Mar 27, 2005 01:15 PM
