99 Civic throwing P1768, P1298, P0135, P0141 after jump starting friend's truck
Old Jul 20, 2013 | 04:26 PM
a6killa's Avatar
Default 99 Civic throwing P1768, P1298, P0135, P0141 after jump starting friend's truck
Sisters Car: 1999 Auto 4D civic LX
Issue: not sure if it's all related but sister assisted jump starting B-Friends truck; tried x 2 with truck ending up having alternator issues.
while jumpers where hooked up and civic idling it suddenly turned off; unable to fire back up. ended up replacing ICM and ignition coil resulting in successful start up but now with check engine light on and throwing P1768 code/D4 flashing and couple other O2 sensor codes. car jerks into gear when manually shifting down the gears; the car will not auto shift.
Would replacing the trans. shift solenoids easily fix this issue? Or is my sister unlucky and will need trans work? any input greatly appreciated
Old Jul 20, 2013 | 04:34 PM
jbpnoman's Avatar
Default Re: 1999 Civic P1768
Start off by resetting the ECU and see what codes come back.
Old Jul 20, 2013 | 04:54 PM
a6killa's Avatar
I have reset the ECU. Erased the codes. No improvement.
Old Jul 20, 2013 | 04:58 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
I had kind of the same issue a while back, nothing was actually done, but was fixed..check your tranny solenoid. but most likely, the solenoid inside the tranny.
Old Jul 20, 2013 | 05:03 PM
jbpnoman's Avatar
Follow these flowcharts, do a 3x3 drain/fill. Courtesy of RonJ:
Old Jul 20, 2013 | 06:05 PM
Marvin1985's Avatar
When she assisted jumping the truck, did they connect all jumper cable points to both batteries instead of grounding off the 1 negative? Probably shorted some stuff out
Old Jul 20, 2013 | 06:22 PM
a6killa's Avatar
She connected the cable clips + to + and - to - of both batteries. think there is a code that states some power surge. looked into it and remember it mentioning a metal clip possibly cutting into wire harness.
Old Jul 20, 2013 | 06:24 PM
a6killa's Avatar
easy access for the internal solenoid? liner solenoid, right?
Old Jul 20, 2013 | 06:49 PM
Ferio Wdm Edition
Well when i got it checked, autozone said it was the lock out clutch, but it wasnt that...theres more to the story. but Anyway, i believe its on the inside of the housing.
Old Jul 20, 2013 | 08:46 PM
Former User's Avatar
Reset the ECU to clear all codes. Then drive car and when the CEL turns on, pull the codes again. Post ALL codes that are recovered after the ECU reset.
Old Jul 20, 2013 | 09:01 PM
a6killa's Avatar
The four codes that showed up are P1768,P1298 ,P0135 ,P0141
Old Jul 20, 2013 | 09:04 PM
When you turn the key from off to ON(II), does the charging system light (battery symbol) in the cluster turn on and stay on?
Old Jul 20, 2013 | 09:37 PM
a6killa's Avatar
no battery light. just check engine, flashing D4, oil light symbol, and seatbelt symbol.
Old Jul 20, 2013 | 09:39 PM
Replace 7.5A dash fuse 15 and then do this test again:
Also check whether the charging system light now turns on and stays on with key in ON(II)/engine off and then turns off after engine is started.
Old Jul 21, 2013 | 07:11 AM
a6killa's Avatar
Oh, so the battery symbol should have been showing? Noob question, which is fuse 15?
Old Jul 21, 2013 | 07:21 AM
Yes.
The circuits throwing all of your CEL codes are protected by fuse 15. The fact that the charging system warning light does not turn on suggests that fuse 15 is blown. A blown fuse 15 can throw all the codes you are seeing.
Install a new 7.5A fuse into the fuse 15 slot to see whether this resolves the problems. Verify that fuse 15 does not blow again by checking whether the charging system warning light always turns on and stays on with the key in ON(II)/engine off.
You will find fuse box diagrams at a link in the FAQs sticky. See Electrical section.
Old Jul 21, 2013 | 08:50 AM
a6killa's Avatar
Yes.
Will get back to you with results
Old Jul 21, 2013 | 01:38 PM
a6killa's Avatar
Yes.
Ronj@HT you are the man. All that was related to a simple 7.5 fuse. You saved my sister $$$$
Old Jul 21, 2013 | 01:49 PM
Default Re: 99 Civic throwing P1768, P1298, P0135, P0141 after jump starting friend's truck
Old Jul 21, 2013 | 06:02 PM
R-Spec Ferio's Avatar
RonJ FTW!
German_Accord
Apr 20, 2013 05:09 PM
itsnotfast
12
Aug 17, 2011 07:52 PM
bizak
May 26, 2011 06:51 PM
teamjdm239
May 6, 2011 05:34 AM
