Honda CR-V & Element 2WD & 4WD Element & CR-V
crank sensor on my CR-V
Old Jul 19, 2013 | 05:49 PM
grimybill's Avatar
Default crank sensor on my CR-V
Can the crankshaft sensor be bypassed? Are there any relays between that sensor and the main point of power supply?
Old Jul 19, 2013 | 05:52 PM
grimybill's Avatar
Default Re: crank sensor on my CR-V
It's a '98 with a 2.0 liter engine, if that is important.
Also on a '98 CR-V, what are the common problems with a distributor ignition module that does not have a coil pack?
Old Jul 19, 2013 | 07:50 PM
saccord's Avatar
The sensor can be bypassed.. Look up "obd-1 swap in an ek"... If you go in the civic FAQ page here on Honda tech and then go to i believe "swap wiring" and go to ckf bypass. It will show you exactly how to do it.. It requires two wire splices at the ecu.
Old Jul 19, 2013 | 07:51 PM
saccord's Avatar
http://technet.ff-squad.com/ckftrick.htm
Old Jul 20, 2013 | 02:26 AM
HondaPartsHero's Avatar
Technical Hero
What is the issue you are having to be more specific?
Old Jul 22, 2013 | 10:07 AM
dogbiscuit's Avatar
ckf trick saccord posted worked on my crv. I put a JDM B20 in it and JDM engines don't have the ckf sensor.
Now my only problem is a damn code for the damn evap system and a random cyl 1 missfire that happens like once every 2 weeks.
Old Jul 22, 2013 | 09:35 PM
grimybill's Avatar
It stops running when the engine gets warmed up. I can drive it around the block, but can't get across town.
Old Jul 28, 2013 | 01:53 AM
swordofdoom's Avatar
A lot of the JDM motors don't have EVAP systems since they don't smog like the US.
Your best bet especially if you have a manual is to use a JDM ECU or best yet just convert to obd1 chipped.
Old Jul 29, 2013 | 12:30 PM
Technical Hero
Icon6 SRe: crank sensor on my CR-V
And why do you think it's the crank sensor?
hondaclown
Jul 17, 2023 08:14 AM
mikester1222
May 7, 2009 09:35 PM
rev2ninetyper
Jul 29, 2004 10:37 AM
