is T3 to big for sohc
Old Oct 24, 2002 | 05:41 PM
KevronsEG's Avatar
Default is T3 to big for sohc
d16z6 in crx
wondering
Old Oct 24, 2002 | 05:49 PM
*Boostwerks*'s Avatar
Default Re: is T3 to big for sohc (CIV616)
no.
But you really didn't give enough info to tell if its correctly sized FOR YOUR application.
Old Oct 24, 2002 | 05:56 PM
KevronsEG's Avatar
Default Re: is T3 to big for sohc (Bryson)
8-10 psi on d16z6 in crx stock motor just tubro kit. with 310cc and 8:1 fmu or 450cc and smc. t3 that is 42 and 48 is what size would be.
Old Oct 24, 2002 | 06:09 PM
sounds good
That turbo will have a fast as hell spool
Old Oct 24, 2002 | 07:17 PM
GasHuffer's Avatar
That turbo should kick *** for your setup, let us know how it works.
Old Oct 25, 2002 | 05:45 AM
KevronsEG's Avatar
Default Re: is T3 to big for sohc (GasHuffer)
well right know i have a rbh5 from mazda 626 and it spools so dfast its not funny, running 8psi and i think i will make more power with t3 i dynoed and teh tubro fell of around 5000 rpm so i need to get some more flow and bigger turbo.
Old Oct 25, 2002 | 09:09 AM
M.A.R.C.'s Avatar
I have a T3 60-trim, .60a/r compressor and .48 turbine... and i dunno if i have a leak or something but mind doesn't spool 6psi till like 3800-4000. I'm running 2.5" downpipe stock cat and 2.5" cat back. does this sound normal?
Old Oct 29, 2002 | 02:34 AM
KevronsEG's Avatar
Default Re: is T3 to big for sohc (CivicRyda2k)
Old Oct 29, 2002 | 04:12 AM
RGAZ's Avatar
New User
With the .60 a/r yes that is normal. I would expect a 3500-4000 full boost rpm with that setup.
Randy
Old Oct 29, 2002 | 11:30 AM
M.A.R.C.'s Avatar
Default Re: is T3 to big for sohc (RGAZ)
Randy
even though it's a .48 turbine?
Old Oct 29, 2002 | 01:50 PM
gtcali's Avatar
Any thoughts on .63 turbine housing on a d16z6? Too big?
Old Oct 29, 2002 | 02:12 PM
ArizonaTurbo's Avatar
Default Re: is T3 to big for sohc (gtcali)
The .63 A/R housing will have more lag than the .48 A/R housing, but you should have really nice top end with the .63 housing. It may be too big for someone who wants a quick spolling street car, otherwise it is a nice turbo if you have a fully built SOHC or your want to produce as much power as possible.
Old Oct 29, 2002 | 02:27 PM
gtcali's Avatar
Default Re: is T3 to big for sohc (TurbochargedSER)
Semi built (stock sleeves). 10-12 psi max.
Find a .48 housing.?
trooper0641
Aug 22, 2005 06:55 AM
integracivic94
Oct 17, 2004 09:19 AM
egturbo
Apr 8, 2004 08:37 AM
808eg6
Mar 12, 2002 01:19 PM
gtcali
Jan 23, 2002 01:52 PM
