93 del sol speedo dosent work help!!!!
Old Jul 15, 2013 | 07:48 PM
delsoldriver96's Avatar
Icon3 93 del sol speedo dosent work help!!!!
Hi I have a 1993 Honda del sol si. I just got the car and I love it except for one problem the speedometer dosent work at all. The odometer and the tac and everything works but I can't tell how fast I'm going and that gets to be a problem at times. Any idea what could be wrong?? Please help!!!!
Old Jul 15, 2013 | 07:54 PM
CO671's Avatar
Default Re: 93 del sol speedo dosent work help!!!!
VSS or needle was once removed but poorly put back into place.
Is there any CEL? Check Engine Light. Have you checked the VSS fuse in the fuse box?
If you Google'd it would've been WAY quicker than waiting for somebody on the forum to reply.
Old Jul 15, 2013 | 08:06 PM
I pulled it out and noticed on the back of the circuit board there was a spot that looks like it got hot and burnt up any way to fix that without getting new Speedo???
Old Jul 15, 2013 | 08:08 PM
Would the vss fuse allow the odometer to still work??
Old Jul 15, 2013 | 08:09 PM
CO671's Avatar
If it's only a solder point, solder it.
Read this thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-civic-speedometer-fix-2792878/
Old Jul 15, 2013 | 08:12 PM
I'm going to try that in a little bit ill post tomorrow and tell if it works or not!!
Old Jul 16, 2013 | 11:31 AM
Vss fuse is good and it still dosent work haven't soldered points yet will do that in a minute
And also the cel is off
Old Jul 16, 2013 | 05:59 PM
Cel kicked on cuz I put on headers and didn't hook up the o2 sensor and soldierd it today and it didn't fix anything. Looks like I'm off to the junkyard to hopefully find one that will work in my car
Old Jul 17, 2013 | 01:44 AM
GSXRedline's Avatar
From advice I've seen on thru google and from Eric the car guy it could just be your speed sensor but I'm unsure... I myself am having a simular issue. My Speedo works fine but every once in a while it will wag around to 5-10 under and over what my speed is
Now I'm not sure if mine has a glitch or something to do with the gauge itself. but does anyone have any suggestions?
Old Jul 31, 2013 | 09:38 AM
i finally bought a new cluster and it works perfect! i have 1 extra cluster for sale now that works and one that needs a speedometer put in. 50 for the perfect one 20 for the one that needs a speedometer
Bipolarcivic
12
Mar 27, 2016 03:34 PM
Ohio del sol
Mar 9, 2013 04:36 AM
sto4gcivic
Aug 28, 2008 03:58 PM
5thGenFanatic
Nov 6, 2006 10:32 AM
