Loose shifter
Old Jul 14, 2013 | 01:39 PM
gitarman2's Avatar
Default Loose shifter
I have a 96 civic dx with a B series engine. I realize the problem to my loose shifter is the bushings. Im going to get a set of ES stabilizer bushings but do I need the ones for a B or D series engine? I know my engine is B but would the shifter also be from a B?
Old Jul 14, 2013 | 02:27 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Loose shifter
Hm. B-series engine with B-series linkage. What do you think?
Old Jul 14, 2013 | 02:30 PM
CO671's Avatar
Yeah, B-Shifters are wider than D-Shifters by this much:
http://www.superhonda.com/forum/f94/...-civic-176204/
Here's some link on changing shifters if you don't know how to get to the bushings:
http://www.team-integra.net/forum/19...stall-diy.html
Old Jul 14, 2013 | 04:50 PM
teamXteg's Avatar
#11 & #8 could b the problem. i had 8 break on me and the shifter and a lot of play up and down. got a new one from honda.. fixed it hopefully that helps
Old Jul 14, 2013 | 05:27 PM
instrument's Avatar
I would try to tighten things up first, if you're doing it yourself.
Old Jul 14, 2013 | 06:31 PM
gitarman2's Avatar
Yeah my play is from left to right. In and out of gear
Old Jul 15, 2013 | 04:37 AM
nealnanoHX's Avatar
I had to replace #8 on my shifter. Made a huge difference in left and right play.
Old Jul 15, 2013 | 01:26 PM
gitarman2's Avatar
I crawled under the car today to have a look and think I figured out the problem. Everything on the shifter is fine but the looseness is coming from the transmission side of the linkage. Ill post a video. When I move the linkage I can hear something inside the transmission moving also. And since this started, I have had trouble shifting into reverse, now I cant get into reverse at all.
Here is a link to the video
Old Jul 15, 2013 | 01:35 PM
teamXteg's Avatar
Icon4 Re: Loose shifter
Here is a link to the video Loose Shifter - YouTube
possible the shift fork inside the tranny is broken?
ninetwoG2
Jun 11, 2013 02:33 PM
4tika4
Oct 3, 2009 08:13 AM
BDM
Sep 24, 2009 02:16 AM
SlowB16
Mar 30, 2008 09:58 AM
95sloweg
Aug 15, 2007 08:00 PM
