Help people I need someone that read code on obd1 video inside
Ok guy my problem is that I make the car front dpfi to mpfi and the car start good the first time I but the key in on but don't wanna rep night then 3,200 I check all the wiring and everything look good I put the e u in my other car and work good to the motor is a d16z6 with stock p28
Sorry for my English guy
I use this to convert he car to mpfi
http://www.b20vtec.com/forums/techni...-diagrams.html
Here is the video of the code the car is conver to obd1
That first code 7 is for your TPS(throttle position sensor). That code for sure will def cause those problems because I just went through this issue with my TPS. Get a multimeter and check for voltage at the middle wire on your TPS. Get the voltage for the throttle closed and then at Wide Open Throttle. I think it should be around 0.5 closed and around 4.5 at WOT. Code 10 is Intake Air Temp which I doubt is causing you these problems. Code 14 is IACV.
And what u gy up think about the dpfi to mpfi conversion in the ling is good guy bec I switch the tps wire like the ling say
Make sure you put the connectors on the correct sensors.
Some of them look exactly the same and accidentally get put on the wrong sensor.
Put the key in the on position. Probe the middle wire. Should be around 0.5volts. Now, have someone hold it at WOT and probe that same middle wire and it should be around 4.5 to 5 volts. Try that and report back.
