MFactory Forged Gear Sets - The #1 Gear Set for your Honda
Hello Honda-Tech,
our #1 best-selling Forged Gear Sets are always in stock and ready to ship!
Close Ratio Gears - Street Series
Suitable for: Street Cars, Road/Race
Power Rating: ~350whp
Warranty: Manufacturers Defects upon Receipt & Initial Installation
Why MFactory?: Our Close Ratio Gears have been proven to be Stronger, Lighter and better performing than our competition
Fitments:
Honda B16A/16B/18C:
1st - 3.070 (Semi-Helical)
2nd - Re-use OEM 2nd gear
3rd - 1.625, 1.652 or 1.695
4th - 1.296 or 1.384 (Slight modification may be required to transmission casing when installing 1.384)
5th - 1.000, 1.033, 1.130 or 1.210 (Slight modification may be required to transmission casing when installing 1.130 and 1.210)
Price:
1st Gear - $264.95 inc FREE Shipping within Mainland US
Choice of 3rd, 4th or 5th - $369.95 inc FREE Shipping within Mainland US
Choice of 3rd/4th - $659.95 inc FREE Shipping within Mainland US
Choice of 3rd/4th/5th - $799.95 inc FREE Shipping within Mainland US
Package Deal: Get 6L of Torco MTF for only $37 or 6L of Torco RTF for only $78.10 when ordered at the same time. Mainland US Only. $18.95 shipping applies
DIY Special: Get an additional 10% discount off our Carbon Synchros, Synchro/Slider Kits and Master Rebuild Kits when ordered at the same time
Free Rebuild Service: Order our DIY Special and we will rebuild your gear stacks for you Free-Of-Charge. No more worries about setting tolerances or rebuilding your gears stacks incorrectly; just plug-n-play. Mainland US Only. $22 shipping applies
Honda D15/16:
1st - 3.083 (Fits Cable & Hydro)
3rd - 1.565
4th - 1.250 (Re-use OEM 3rd Gear)
5th - 1.000
Price:
1st - $264.95 inc FREE Shipping within Mainland US
Choice of 3rd or 5th - $369.95 inc FREE Shipping within Mainland US
3rd/5th - $649.95 inc FREE Shipping within Mainland US
Honda H22A:
1st - Re-use OEM 1st Gear
5th - Re-use OEM 5th Gear
Price:
Choice of 3rd or 4th - $369.95 inc FREE Shipping within Mainland US
Close Ratio Gears - Road/Race Series
Power Rating: ~500whp
Honda B16A/16B/18C (3rd/4th/5th are Straight-Cut Gears):
3rd - 1.636, 1.670 or 1.704
4th - 1.313, 1.355 or 1.387 (Slight modification may be required to transmission casing when installing 1.355 and 1.387)
5th - 1.028, 1.118 or 1.210 (Slight modification may be required to transmission casing when installing 1.118 and 1.210)
Price:
Honda H22A (3rd/4th are Straight-Cut Gears):
Price:
Honda K20A:
1st - 3.130 (Can be used with the OEM Mainshaft. This longer 1st gear is suitable for those that require extra traction off the line, and is especially useful for those running a higher-ratio final drive. Can be purchased standalone. Does not require the use of our full gear set)
2nd - 2.167 (includes new Mainshaft. Can be used with OEM 1st Gear. Does not require the use of our full gear set). The solution to the weak oem K20 2nd Gear
3rd - 1.647
4th - 1.286
5th - 1.043
6th - 0.851
Price:
1st Gear - $369.95 inc FREE Shipping within Mainland US
2nd Gear - $1299.95 inc FREE Shipping within Mainland US
1st & 2nd - $1599.95 inc FREE Shipping within Mainland US
3rd-5th - $1299.95 inc FREE Shipping within Mainland US
3rd-6th - $1499.95 inc FREE Shipping within Mainland US
1st-5th - $2799.95 inc FREE Shipping within Mainland US
1st-6th - $2999.95 inc FREE Shipping within Mainland US
Final Drive Gears
Power Rating: ~300whp
Why MFactory?: Our Final Drive Gears have been proven to be Stronger, Lighter and better performing than our competition
By changing your final gear ratios, you can experience a dramatic increase in acceleration, giving you on average, a 10-15% increase in torque throughout the entire rev-range over the OEM Final Drive. CLICK HERE to see how much power you could gain!
Honda B16A2 Fitments: Will not fit models equipped with Factory LSD
Honda Cable Fitments: Will not fit models equipped with Factory LSD. 92-93 YS1 transmissions should use B16A2 fitments
Honda '98 Spec Fitments: Designed for the '98 Spec Integra Type-R with Factory 4.785 Final Drive
Honda H22A Fitments: Will not fit ATTS-equipped transmissions. Is also suitable for Euro-R/Accord Type-R
Fitments:
B16A Cable (Non-oem LSD) - 4.928
B16A2 Hydro (Non-oem LSD) - 4.0*, 4.267, 4.533*, 4.600*, 4.71*, 4.923*, 5.167*
B16B/18C - 4.0*, 4.267, 4.71*, 4.923*, 5.167*
B18C JDM '98 Spec - 4.0*, 4.267, 4.71*, 4.923*, 5.167*
D15/16 - 4.5, 4.7, 4.9
H22A/F20B - 4.64, 5.15
L15 FIT - 4.47, 4.687
K20/24 - 5.08, 5.417*, 5.84, 6.33
S2000 - 3.90, 4.40, 4.57
R18A - 4.687, 4.928
CR-Z - 4.687, 4.928
*: Offering a revised design over our previous generation Final Drive Gears. Forged from stronger steel with a 50% larger tooth profile yet almost 1kg lighter!
Price:
B-Series / H-Series / FIT / S2000 / R18A / CR-Z - $579.95 inc FREE Shipping within Mainland US
B-Series 5.167 - $609.95 inc FREE Shipping within Mainland US
K-Series / H-Series 5.15 - $749.95 inc FREE Shipping within Mainland US
D-Series - $564.95 inc FREE Shipping within Mainland US
How to order: Please send us a PM
<---------- IMPORTANT NOTICE ---------->
We have recently become aware of cheap and inferior "copies" of our Final Drives & Close Ratio Gear Sets, including our own custom ratios, being made available on the market. These DO NOT go through the same forging and heat treatment processes and will compromise your safety if installed on your vehicle. STAY SAFE and only purchase your Final Drives & Close Ratio Gears Sets from an Authorized MFactory Dealer
Fitments:
Honda B16A/16B/18C:
Price:
Honda D15/16:
3rd - 1.565
5th - 1.000
Price:
Honda H22A:
Price:
Price:
Price:
Honda K20A:
3rd - 1.647
4th - 1.286
5th - 1.043
6th - 0.851
Price:
Final Drive Gears
Fitments:
R18A - 4.687, 4.928
CR-Z - 4.687, 4.928
Price:
shouldn't the power rating for the k series gears be a little higher? stock k series gear box can take more power than about 300whp going down the track with multiple passes
This is just a conservative rating for reliability.
Nothing is unbreakable, and there are so many variables involved when something goes wrong that it can sometimes be hard to determine what the problem was.
If we were to rate them higher and they were to break, it is always the manufacturer that gets blamed. It is never the end-users fault
Even a $20,000 transmission can break under stock power. Been there, done that.
Keep the orders coming
If you have any questions, please feel free to send me a PM.
To order online, please click here: www.teamMFactory.com
Rickvanuden
Transmission & Drivetrain
Jun 8, 2017 09:00 AM
ExospeedAMcrx
Nov 2, 2009 09:44 PM
