Diagnosing CONSTANT spark in cylinder 4
I have been fighting this M&W pro10 ignition for a while now, and keep having issues. upon IGN1 and IGN2 the Crane PS92 coil makes a loud buzzing sound and cylinder 4 has a constant spark, 1,2 & 3 fire in sequence on cranking but what reasons could be causing this constant spark?
Built H22
S366
S300
M&W Pro10
Crane PS92
BKR8E-11 plugs
Built H22
S366
S300
M&W Pro10
Crane PS92
BKR8E-11 plugs
Have you verified the ECU is working properly? Have you tried a different ECU?
I'd try a different M&W if the ECU tests out fine. I believe Tony @ T1 has a test fixture for M&W components.
I will try a different ECU see what that does. I went back to the stock setup and cannot get it to start, but the cyl 4 constant spark went away. I just really am at a loss to what is happening because I haven't changed anything and these issues are just appearing now.
Who is Mr Robot?
Mice are the devil
Why won't it start with the stock setup? any rewiring been done to any pinouts? Still have the big injectors in?
ex_ricer
Aug 14, 2008 11:42 AM
